Primitive entertainment center
As promised, here is a pic of the entertainment center I made.
[External image (sphotos-a.xx.fbcdn.net), not copied]
Looks great, do yo have the cabinets set up to accept DVDs?
Yep. Each side cabinet holds up to 40 DVD’s. On the bottom I outfitted one side with shelves and the other is a big open space for hiding larger junk.
[External image (sphotos-b.xx.fbcdn.net), not copied]
I also built it as two separate pieces. The top is removable so it can be used as a stand only and makes it 10 times easier to move. I built a lip into the back where it attaches so no light comes through. If you didn’t know it was built separate you’d never be able to tell. I’ve built lots of similar stuff, but this is the largest so far.
You can not beat getting stuck in and making something with your own hands.
Well done Pal keep it up and hope to see more projects you have made. 🙂
That is awesome. Great job. Wish I had the time to start doing some woodworking again.
