Bathroom Remodel
So I am getting started remodeling our kids bathroom. I have the tub pulled and am now starting to remove the existing floor. I’m not much of a remodeler but I haven’t seen a subfloor quite like this. Under the tub are 1″ boards. Under the rest of the floor there are two layers of linoleum, some type of tile and then mortar with chicken wire. The strange thing is that it drops lower than the floor joists. Not sure if that makes sense or if anyone has seen this before. I figure I’ll try to post some pictures of the progress.[External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
hathatylMember since Sep 2013
Looks like you got a mess on your hands kruton.  Ive heard of the chicken wire and mortar technique, but only for tubs that need reinforcement underneath. Was it a heavy tub like cast iron or clawfoot?
ya looks like a gut job to do it properly floor wise, hopefully it isn’t water damage from years and years. you won’t want to put anything over it. Time to buy a Milwaukee SDS and get it working in chipping mode
Should look good when it’s done
Yowsa, thats a lot of flooring someone never bothered removing, are you saying the boards are recessed between the joists, thats what makes the floor so low?
The tub was cast iron but the mortar wasn’t under the tub it was under the rest of the floor. That’s what seemed strange to me. I forgot to mention the house was built in the early 1950s in case that helps. Not sure if maybe that was the technique at the time. I’m planning on busting it all out and then putting new subfloor down. Shouldn’t be too bad since the bathroom isn’t that big…but that’s assuming no more surprises!
yes hopefully the joists are not damaged from water or you may have a bigger problem.
Now you have me wanting to buy an SDS rotary hammer!
depending how soft or easily broken up the floor will be an SDS may not be out of the question……
That’s what sucks with older homes, something as simple as swapping out a light fixture leads to a huge project.
Ha ya know you mean and then somehow one showed up at my door, oops how did that happen ha
You know it Jimbo, then when I’m up on the ladder putting the new light in, I notice the bulkhead over the kitchen cabinets is falling off the ceiling, and realize the previous owner just used 8d nails thru 2×2 to hold it up, so that has to all come down, and with it the old cabinets might as well get replaced, well now the plaster on the wall pulled off, time to gut the kitchen, then there’s an old chimney they just covered up with a frame, means I gotta patch the ceiling where it went through, oops they didn’t even space the studs right, hodge podge of wood in the wall, didn’t even put proper studs around the kitchen window, aw man, the walls aren’t square, well just have to fudge it cheese whiz where does it end……
Hope you can keep from going crazy, kruton
that pretty much nails it but lightly you don’t want to put in a new stair case…..
This is hilarious you say that because I actually had to do that! Well not a compete staircase, but I bought the place and they had it half completed basically, so I put a closet under the stairs, new treads and risers, new trim, new railing, new carpet.
Oops hijacking your post sorry kruton
Maybe you’ll find some fossilized chickens under that wire.
They may have just used the chicken wire and mortor to raise the one lower section to the other higher part. Maybe something settled or they added on an miss figuered there numbers and didn’t come up to the same heigth on block work or something? And they had the wire and mortar laying around. Instead of paying for more plywood or ripping filler strips to make up the difference. They used what they had? Hard times I guess. it’s always hard to figure stuff out without being there. I’ll stop rambling on and on.
Millerz
I feel your pain, has we are remodeling the 1/2 bath.  I will get busy posting some pictures in my thread
Good luck wigwag. It’s always interesting to see what you find when you start demo!
Well tearing out this floor is slow going. The chicken wire is definitely doing a great job keeping the mortar together. I really wish it did not do this well! [External image (uploads.tapatalk-cdn.com), not copied] Thank the Lord this is a small bathroom!
So far so good brotha can’t wait to see how it turns out man! Buying any new tools for this project?
Nothing right now, but probably will when I start tiling. I’ll probably think of something new to buy though!
You using an sds drill?
You’re still making some progress, even if just a little. Rotary hammer is a good idea like Jimbo mentioned
Man Kruton, your bathroom floor looks like mine did when I first moved in and did a remodel. Don’t you love that old world mud job with the wire lath PIA! Looking good man!
No. I thought about buying one but figured I don’t really need one very often. Just using the old Estwing 16oz and a 3 lb hammer.
That work will earn you a few beers!
Yer darn right it will! [External image (uploads.tapatalk-cdn.com), not copied]
Nice choice I can only drink one of them though they are pretty sweet, still haven’t tried their ginger beer yet.
I’m the same way. I grabbed a second one once and couldn’t finish it. Just too sweet. I’ve just heard of the ginger beer but never tried it.
The root beer is good with ice cream though
T75RMember since Jan 2016
Root beer is always good with ice cream!
99_XC600Member since Jun 2015
Best way to drink those is over ice. The colder the better.
that guy on the bottle, was he the guy that put the original floor in your bathroom…..
I think the guy on the bottle was his son!
Quite the project Kruton! Can’t wait to see more pics. Also…..trying the not your daddy’s with vanilla ice cream sounds pretty friggin’ awesome. Now I HAVE to try that!
Booze and ice cream…win win baby!
I have not seen something like that in a long time. How old is your house. and is this a second floor bathroom. Back in the day the would fill the joist bays with sand or a dry cement mix the put down a scratch coat down wire then the cement floor. from what I see instead of removing the old floor they keep going over top of the old floor. So be careful removing the old stuff or you could have a lower room full of who knows what.
Stay away from the ginger beer
No good?
The house was built in the early 50s and it is a second floor bathroom. Luckily the garage is directly below it so it shouldn’t be a major issue with stuff falling. It’s strange but it’s like they used one by material in the joist bays about an inch lower than the joists. Then they put a couple layers of tar paper, then the chicken wire and then mortar with tiles above that. I’ll grab some pictures this afternoon .
Here is a pic of the boards between the joists. [External image (uploads.tapatalk-cdn.com), not copied]
I grew up in an older neighborhood, (my parents still live there) and the house across the street was purchased from a Sears catalog.  After the original owner had passed away and sold the house, the family that bought the place did a complete remodel.  I remember my brother talking to them about all they crazy stuff they found behind the walls.  I do remember there being a huge hole in the middle of the kitchen, that a big block Chevy motor caused.  The old guy was rebuilding it durning the winter lol.  NOTE: This was back in the 70’s and I was still a little kid.
Sorry for the hijack, looking at that flooring brought back some awesome childhood memories..
This bathroom remodel has been slow going. We have had a lot going on and my free time to work on it has been few and far between. Got the old paneling off the wall and the subfloor down. Next to install the tub and fix the walls. Slowly but surely I guess![External image (uploads.tapatalk-cdn.com), not copied]
Slowly but surely is right, plus a few other side quests along the way, always something when you own a property. ..
Having three small kids helps to derail progress as well. I’m taking a couple days off this week so I can get an entire day of uninterrupted work done!
PROTOOLNUT wrote:
I can see why you are remodeling the bathroom, that sucker was grose before. I assume you will be installing a brand new efficient toilet?
He should install a bidet!! Lol I’m going to refrain from any further with this comment
For a toilet. I would recommend a handicap/comfort height model, The seat is 2-3 inches higher than a standard toilet and is much more comfortable when you’re taking care of business.
I put a Kohler unit in my upstairs bath and it’s awesome. (For a toilet)
kruton wrote:
The house was built in the early 50s and it is a second floor bathroom. Luckily the garage is directly below it so it shouldn’t be a major issue with stuff falling. It’s strange but it’s like they used one by material in the joist bays about an inch lower than the joists. Then they put a couple layers of tar paper, then the chicken wire and then mortar with tiles above that. I’ll grab some pictures this afternoon .Sent from my SM-N900V using Tapatalk
It’s actually not gross, just old cast iron. I’ve got a brand new dual flush toilet that the previous owners put in just before I bought the house a year ago. I am just going to put it back because it is a very nice toilet. Jimbo, I don’t know if I would know how to use a bidet! I would probably just use it like Crocodile Dundee to wash my boots.
Ive never used one but i hear its quite the experience, buddy of mine went up to kohler, wisconson and had the privilege of shitting in a $4000 toilet that had a bidet and all sorts of climate control seating and speakers and stuff… yea, as long as i got a bowl to shit in I’m a happy man!
That’s a little too high class for my ass…literally!
