Good Day Crew!
I am about to embark on my first bathroom remodel project. I will be replacing the vanity, sink, faucet, mirror, and lighting in our 1/2 bathroom. Anyone on the TIA crew have any advice, tips, or tricks? I am hoping I won’t have to re-route any of the plumbing lines to accommodate the new vanity, but won’t know that till I remove the old one. Since this is technically me ladies “powder room”, if it involves any tools I don’t already have, I will get to buy them lol.
Thank You all in advance,
-Steven
all depends on how the old one was installed, old house newer house, some old houses had build ins how is the rest of the wall of the room, when you remove vanity are all the walls ok if you have to do any flooring do it first……
Instead of a vanity cabinet, you might consider a pedestal sink. Gives the illusion of more space in a small room. Weather or not you do something like that, I would still apply floor covering (i.e. tile/vinyl) before setting a vanity. This leaves room to change your mind at a later date, and does not really cost any extra if done now.
Pedestal sink is a good idea, my advice is to make sure you measure old-versus-new. I installed two new vanities in our bathrooms, and both times I had to run back to the store to get extensions for the pipe. No big deal but if I had measured the height I wouldn’t have had to make two trips. With the vanity in our bathroom I had to notch out the back, there is a divider wall between the cabinet side and the drawer side, and it butted up against the cold water valve. Had to use the multi-tool to cut out a piece of the “wall” to accommodate. Again, no big deal but it would have been nice to have known before I shoved the thing against the wall.
all 5 minute jobs have a 4-6 hour window….lol
When you are putting the new sink and vanity in. Put as much of the hardware on the sink as possible. Like the faucet and handles stopper plumbers putty stuff like that before mounting the sink. And you may need a sink extension to go from the sink to the trap?if your using taller cabinets
Millerz
I’m predict a trip to the tool department.
Whatever tools are on your wish list…… your gonna need. Go get em
She already picked out the new vanity, she had her heart set on it lol. The house was built in 2004.
Must be nice I’m sure the floor is level, the walls square, and no old chimney running up through the one wall, unlike mine….. ha.
Zach is right, it’s so much easier putting on your faucet and sink tail piece before you set it, pedestal or not.
I agree with the pedestal sink idea, I did that to my bathroom and actually love it, contrary to my original speculations
Make sure to post pics please Steve
I am thinking the new DeWalt 20v Reciprocating Saw, and the DeWalt 20v Oscillating Tool w/ 29 pc Accessory Kit LOL
She has her heart set on a certain vanity, in fact she already bought it. I think the stone floor tile goes under the current vanity, if not we have extras we can install.
So you said you bought some new tools for this project, do tell!WigWagWorkshop wrote:
I am working on a video, I did make a post in the power tool section “What did you buy today” on what I purchased.
Things are definitely not going well, nicked the copper pipe when I was trying to remove the bottom of the old vanity. The plumbing comes up through the floor on the same side as the drawers of the new vanity. So I am either going to need to move the plumbing over, or switch over the door and drawers on the new vanity. Also I am going to need to lay tile down, has there is the old linoleum under the old vanity.
something is wrong if EVERYTHING goes smooth….you just don’t know it yet…….this way you do!
I always hated having to install a cabinet over plumbing stubbed out of the floor instead of the back wall. Almost always would have some silly issue with alignment that would require extra time and effort, when punching holes in the base.
I feel your pain that sucks
Eeh just move the plumbing, just an average day at work ha
I’ve ran into this dozens of times… However I’m willing to bet the drawers on the new unit don’t go all the way back, therefore you’ll have room for you 1/2″ supply lines.
Wigwag, there is this stuff called Alure at HD. It is a vinyl planking. I used it in my kitchen and addition. Looks just like cherry flooring and is scored easily with a razor and you can easily cut out around curves or whatever. Additionally it is a floating floor system and I used some water proof caulking around my kitchen sink and rear door to prevent water from getting into the subfloor. Anyways the reason I bring this up is j will be smashing out the tile in my bath room and replacing it with Alure tile. Comes in planks, has texture and grout lines but goes together in planks in the same fashion plus it’s waterproof. You can lay it right over the existing floor also. I’ve had mine down since installation for about eight years. Very durable and looks great.
Sounds like some awesome flooring I’ll have to keep that in the back of my mind
yes great product we put it in our main floor bathroom……looks like ceramic tile without the surfing across the floor…..
My Whoops – nicked the pipe when removing the old vanity, BTW this is my very first “big” remodel project.. more pictures coming soon of the remodel.
[External image (farm2.staticflickr.com), not copied]
It doesn’t help that they ran the water and drain up from below versus from the wall.
If you reeeeally want to get a nice finished look under the sink, put the plumbing in the wall instead, just cut open the wall and floor and the rest is easy lol
ha ha whoops!
Yeah, we are looking at doing that, but because of the location in the basement, it might not be possible. I will snap a few photos of the basement for your judgment.
QUESTION – would one take the time to make the wall perfectly smooth behind the vanity that won’t be seen once its installed?
Wigwag, me as a diy’er I would, because I’m that anal about my work. I would think a general contractor would not. It would be more about speed. Time is money. After seeing your pics I can’t help but think how handy a Multitool would help you out. Thanks for sharing, good luck.
That’s exactly what I was thinking! What if down the road we change it again with a lower vanity, then I would have to fix it anyway. Thank You for the feedback, I am going to smooth it out.
If it wasn’t perfect, even though no one else would know it it would drive me nuts, shouldn’t take you too long to make it smooth either.
I need to cut about 8 pieces of stone tile, but don’t have a cutter. I am looking for a low cost method of cutting these, but please keep in mind that they really won’t be seen has it’s just the sides of the vanity, and I don’t plan on ever cutting tile again.
Our old vanity went wall to wall, but the new vanity leaves about 2 inches from the wall on each side.
Can always grab an angle grinder and a tile cutting blade
7 hours ago, JimboS1ice said:Can always grab an angle grinder and a tile cutting blade
Unfortunately, a grinder is a tool I do not own yet. I would consider picking up a cheap HF model, unless I can convince me lady that we need one for other things, so it won’t have to come out of my “do what I want” budget lol.
You would be better off getting a lower end hitachi from lowes or menards
