I grew up working for my dad in construction, then he switched strictly to roofing later on, and that’s the majority of my experience. Well that carried on a little bit when I moved out because people found out, so I did a few roofing projects here and there, even though I was really done with roofing. I’ve still been asked to do a few projects here and there, and just can’t seem to say no to it lol.
This is about a repair that was so laughable, I question the credentials and values of the roofer that did this:
First, wrong flashing for EPDM rubber!
Second, don’t use roof pitch on EPDM rubber!
Third, don’t spread the crap all over the place for when someone has to come back to fix it correctly!
Come to find out, they were no longer using the tankless water heater that the gasline and venting was for, so I just removed everything and made it easy on myself. New piece of EPDM and cleaned all the old roof pitch off (time consuming)
Next pics are conduit with the wrong flashing, wrong sealant, so I removed and put the proper one in place, called “witches hat”
Hey no more leaks
There were a few other wrong flashing in place, so I repeated the process and took care of it permanently
Way to save the day Karl! Yea some guys just shlop anything up to get the job done and get home instead of doing it right.
Good job on the repairs
Question Karl. when I purchased my home, homeowners were required to fix venting in bathroom that vented in to attic. So they connected two bathrooms to 1 pvc pipe through roof then put a tin hat over the top of it. I the winter we constantly get water on br floor due to condensation. Was this done incorrectly.
Good for you knarlycarl, I’m glad you took good care of that. Nice job.
Great job on the repairs Carl, I don’t miss being on the roofs at all only did for about 3ys with my uncle and seen some crazy falls
Also so you dont think im an idiot, I know you said pvc pipe, which would indicate drain vents, but you also said a cap on top, and I’ve seen pvc used for some crazy applications, so I wanted to clear that up.
If you see condensation on the outside of the pipe in your attic, you’ve got a lot of moisture coming into contact with the pipe, kinda a weird scenario but I suppose it’s possible.
Where do you see the moisture when you look at the pipe?
That looks much cleaner. Good job. I hate going back over Other peoples mess ups. I makes me feel better about my craftsmanship though. And so should you.KnarlyCarl wrote:
Hey no more leaks
Millerz
Wow,,, that was a mess, nice up on the corrections Carl
Exhaust fan, and actually see moisture on floor in the bathroom. Especially in the winter.
Ok so the condensation is draining down inside the exhaust venting. If the venting is joined together, there is probably a long run of venting somewhere I’m guessing because the bathrooms are far apart? The venting needs to be as short as possible, to prevent the moisture from cooling down before it reaches the outside which means putting two vents thru the roof. Also no need for pvc, use a proper roof flashing for that kind of thing.
Thanks, that’s what I thought. Weird thing is bathrooms are back to back.
Huh there goes that theory.
How much pvc sticks out the roof? If its enough, that’s probably where the condensation occurs, and then drains back. Id say use a flexible plastic/vinyl venting and attach it to the underside of the vent flashing like I posted so as to not have that length of venting sticking out above the roofline
