Installed some new cabinets an put new cut offs for supply lines. New medicine cabinet. Not hard to do or a lot of work. But it brings home the bacon. Lol
Millerz
Millerzconstruction wrote:
Installed some new cabinets an put new cut offs for supply lines. New medicine cabinet. Not hard to do or a lot of work. But it brings home the bacon. Lol[External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Millerz
See what you did there, I need to, do the same thing. Except I have a window that I need to close up. Looks good.
Thanks glass
Millerz
Nice work millerz.
Needs more clamps.
Thinking maybe a clamp for the clamps?
Nice work. Whatever brings home the bacon.
Good work man
I spy an oatey sure vent lol!
[External image (s3.supplyhouse.com), not copied]
They bought cheep cabinets and wanted the ends caped with thin panneling that you can buy to glue on the ends. So they don’t look as cheep. Took that many clamps to get the panneling to lay flat every where. Any body who works with that stuff knows how bowed the thin strips of panneling are. I needed a couple hundred clamps to of done both ends at the same time. Lol. As you can see I ran out of enuf clamps to do both ends. Lol
Millerz
Gotta go do the other end tommrow. And glue and clamp it all again. If they would of told me they wanted them on to begin with, I could have glued them both at the same time then hung them.
Millerz
Nice job Zach!!
Millerz
Just a tip, instead of clamping all over the piece, cut a piece of 1/2in to 3/4in plywood out of scrap and place it over the glued panel. You could use just a couple clamps to achieve the same amount of dispersed surface pressure, one in each corner would be plenty. This also keeps the surface of your paneling from depressing from the surface pressure of the clamp face as the glue squeezes out at that spot and pushes the panel away from the cabinet all around it, once the glue cures and you remove the clamps you have the risk of it looking like a dimple everywhere you clamp. If you have trouble following what I’m saying (not easy to explain in words) I can make a video demonstration of this to help make sense.
I used 2×4s I had on my truck as whalers. Its better than plywood. Its like what people use to keep forms strait when pouring pires with concreat I just put a couple extra on the side because I had them. Other than the 5 on the side there is only 4 really holding it flat. Thanks thoughHugh Jass wrote:
Millerz
You can’t see them but there are two 2×4s. One in the middle an one a third of the way each way. And the cabinets are only 14 inches wide.
Millerz
Millerz
Whalers…figures there’s a term for it. Of course the more ridged the material the better, was suggesting sheeting because you had enough clamps on one end to do both sides at once. Efficiency is money. =-) Throw up pics of the finished product!
These people are tight. And a sheet of plwood is 30 dollars. I didn’t know they wanted the sides out on in till I was done and got paid by the renter and he asked if I put them up. And never told me about them. So I was Woking with what I had. Lol
Millerz
It’s was 5 in the afternoons when I found out he wanted them. Got paid went strait ther put it on..
Millerz
And the people that live there work night shift and asked if I could come out them up at 2:00 pm.
Millerz
Millerz, Hughs just offering a little advice man, nobody knocking your work dude, he’s just saying that greater surface area pressure comes out with a cleaner look.
No need to get defensive…
Whalers? I thought that sort of clamping mechanism was called a caul. (Honestly asking here, not trying to be a smart ass)
Bet you comp knows!
[External image (media.giphy.com), not copied]
Hugh dude thats my favorite simpsons gif!
Googled it…I believe you’re correct. Good to know since i use them frequently and tend to try to sound like I know what I’m doing when people ask, lol.
Thing are called different stuff on diffent job sites states and country’s. It maybe where you are. I’ve been doing this my whole life. My dad’s a contractor for more than 35 years. And build bridges before that in Atlanta. So I know what a whaler is. Lol
Millerz
i looked up Waler clamps too, appears to be an alternative to snap-tie/pigs feet 2×4 forming/kicker system.
