ok so without looking to hard…..I couldn’t find a Betterley zero clearance insert for my new miter saw so of course I made one……I did it the same way as the fence all in reverse so it does not wear off the name…..
made the insert and fit it first…..drilled the holes to match then cut it out with blade to give it the zero clearance…..
after adding my little betterley touch this is what it looks like…..
other things are I retrofit the rectangular dust port to fit my 4″ hose for dust collection so it is ready for work…..
Impressive as always comp
Sent from my LG-V410 using Tapatalk
Very professional looking comp.
Comp great job as always, what kind of laminate did you use? Why did you put betterley on it and not your name? That thing is classy dude!!! You gotsta represent the Comp!
lol cause I’m not a smart guy and didn’t think of putting my own name on it…lol might now though thanks for the tip….lol
Amazing work Comp!
Well Comp….I’m thinking you should post that pic to betterley and get a royalty!!
Looks great. The stock plates don’t quite close enough for a 90 degree bevel, so this will no doubt be quite the improvement. Now if only there were a quick change mechanism so you could swap out for a bevel zero clearance set on demand you’d be all set. I sense another project in the offing…
