The Bottom of this door was completely rottin. About 4 inches of it I repaired with bondos new wood repair and filler. It worked really good. Then I used a Roto zip to make the small decorative groove on the edge.
How well do you think that will hold up? Is that bondo flexible at all?
I’ve only used it twice. Once on a sign repair and the door. It’s really hard. But I left some room under the bondo were it was rottin below the threshold. We will have to see how it Does. I’ll see it twice a week. It’s at the church I go to.
I’ve only used it twice. Once on a sign repair and the door. It’s really hard. But I left some room under the bondo were it was rottin below the threshold. We will have to see how it Does. I’ll see it twice a week. It’s at the church I go to.BMack37 wrote:
The more I think about it. It seems like that bondo was a little flexible. Not much though. It was about just lik wood would be. That would be the best way to describe it.BMack37 wrote:
I like your repair. You are talented with that rotozip lol. Nice millerzconstruction!!
Awesome, hopefully it will hold up! It sure looks really good!
Looks great.
I would think that it would be fine. It’s nowhere near the hinge area so it shouldn’t be stressed too much.
Did you use a straight edge when you did the groove or freehand it?
Looks good dude, let us know how that bondo holds up
Free hand99_XC600 wrote:
Looks great.
I had to replace part of the door jam on my front door. It looks like crap but its all I could do at the time. I’m not really in the mood to replace it yet. The wood they used was a step above balsa 🙁 It’s crazy how bad some of the wood manufacturers use in some products
one question with the roto zip why not cut a straight line above rot and just replace with new wood? only reason I say this is now that you patched it up in the bottom corner anything that caused this rot in the first place may get behind the bondo and make things worse
Cause bondo doesn’t rot. And I caulk around it. And people at church’s don’t want to spend any more money than they have to. So it was fixed for 8 dollar’s instead of 20 or 25 dollar’s. It’s better and stronger than it would have been another way. And looks better too. And the bondo makes a good seal to keep Any water from getting in. The roof dosnt have enough over hang. So every time it rains it splashes And blows rain in the corners. And it is a 213 year old church. And I didn’t get paid to fix it. Now we don’t have to worry about the splashing and gathering water rotting any wood. Lolcomp56 wrote:
(sic) And people at church’s don’t want to spend any more money than they have to.
Good grief this is so true
And I would have used a oscillating tool to cut the frame if I was going to cut it all the way. To replace it. Or a skill saw And Finnish the cut with the oscillating tool or handsaw.
