Well today picked out some wood for a project I’m doing….going to be making a wood sheath and matching handle for one of my son’s 6 swords. This one is a Bastard Sword or also known as a Hand and a Half.
the wood used will be Padauk also known as Vermillion with Juglans Nigra also known as Dark Walnut
After seeing the sheath you made for his knife I am really looking forward to seeing how this thing turns out!
Looking forward to it Comp, Are you able to pick up these species of wood locally or do you order them?
thanks guys
@Mikeyb ya I have a local guy that usually has pretty much anything I can afford…lol some of this wood is crazy expensive…..looking at Santo Rosewood …..not bad at $44 a board foot……….
anyways here is what I got so far…..have all measurements cut into 3 and marked off for angle cuts. the sheath will have walnut on an angle at top and bottom
I know it’ll look amazing comp, that’s some beautiful wood you got there only a mere $44 a foot lol I know exotic woods get way higher in price.
Awesome Comp
ok so it’s back to square one….(no pun intended) let’s say back to a solid piece of wood again……only difference is now the blade fits perfectly in the square well not really a square…..planed it down to S4S then will sand once I cut out top groove for blade handle and shape bottom end…..
Sweet comp, looks good
Looking great comp!
ok so the scabbard for the sword is complete, from the top to the bottom I tapered it by 1/8″ to a rounded point. here it is after 280/600 grit sanding…..handle is next…….
Work of art right there!
Wow that came out sweet!
thanks guys
got handle done and put everything back together…
Looks awesome comp.
Love the handle
thanks guy I have never drilled a tapered hole before was quite tricky…..especially almost 7″ deep…..with 4″ drill bits….haha
Very beautiful.Love the finger grips in the handle. Comp needs to start a woodworking channel 🙂
comp needs to find a look a like actor that will go on film as comp is camera shy………somebody current, Tom Hardy, Tom Cruise? some actor not very busy……
