I like to work on cars and would like to know what would be the best thing to use that would be gentle enough to help clean my engine but powerful enough to clean my patio and my exterior walls??
Something like this is good enough for home use just make sure you don’t use a crazy tip when you use it on you car 🙂
I think that’s the same model I have DR not 100% sure I’ll double check but if it is mine it has been great Chris I’m surprised u haven’t seen mine yet I’ll let u try it out next time ur down in riverside bro.
They also sell the exact same power washer under the Homelite name as TTI makes both of them.
This would probably work Ryobi is a good brand
On those power washers can you adjust the pressure or is it based on what tip you use??
Usually they just adjust the spray pattern not the pressure itself.
So what do you or how do you adjust the settings on the washer with out compromising the power or pressure??
Its pretty much just by swapping out the tips for more aggressive or a less aggressive spray. Some wants have a twist top that lets you adjust it even more you can idle the motor down more but its not good for the motor or pump really.
Ok so do you have any or know any that you recommend as far as good ones out there!!
Talking about pressure washer? or the wand/tips they come with the pressure washer.
I was asking about if there are different tips to use depending on the use or is it dependent on the power washer??
A lot of people like the Turbo Tips that deliver a rotating spray pattern. I like that Ryboi that Jason posted since it has the Honda engine and the soap chamber.
back in high school there was a girl…..oh wait you said turbo tips……sorry…..
