Concrete Floor Grinder (upright) under $1k
Archived from the Tools In Action forum (FOR SALE). This thread is read-only.
jr2443Member since Feb 2011
I do garage floor epoxy coating for a living and i came across this little gem a couple months ago. It’s a stand up floor grinder with a 7 inch diamond cup wheel. I was a little skeptical about it since it was so cheap but I picked it up and I’m impressed. I can grind down a two car garage in about an hour. It comes with a 15 amp motor @ 3,000 rpm’s, it came with a 7 inch diamond blade, and a dust shroud that I hook up to my wet vac. I don’t understand why all the other floor grinders I see online start at $5k, and this one is so much cheaper. It’s obviously not made for huge jobs, it’s a small unit, but its perfect for what I do. If you’re in the epoxy business, then check this thing out! HGF-1 Concrete Floor Grinder. www.concretefloorgrinder.net
