New Random Orbit Sander…
Lowes has it available to buy online.
which item? link?
the clear one…it is hard to see..
Bryanp292Member since Aug 2014
Here is the sander he’s talking about.
Amazon
PeteWMember since Aug 2014
its the same price as the old model that can’t be right?
William SMember since Jul 2015
I just went to acme and they ended up selling me the old one which had to much vibration. I then did my homework ad found out about this one so went to lowes and picked the new model up. They are both $79.99 and the difference in vibration is noticeable as well as the noise. I don’t know if its a clear upgrade but I do prefer hte newer model for not only the vibration  noise and seemingly better sawdust collection but the new grip is more comfortable as well. they did change the dust collection insert though and while ther older one let me use my 581H this is will need an adaptor.
Rtorres092382Member since Sep 2014
Am I the only one hoping for a 20V sander? Don’t think that runtime would be a big problem when hooked up to a 5.0 ah battery? From what I recall Bosch has one and I’d love to see team yellow jump on that tech.
im sure they will make one but the question is how long till they do……
Anyone know this one compares to the DeWalt D26453?
 I have both at the moment, the D26453 seems to be a bit louder and has a bit more vibration. The DWE6423K is about 1/4″ shorter and has the rubber grip which is nice but not a dealbreaker wither way. The vac attachment is different and you’ll need an extra attachment to use the 581H on the DWE 6423K while the D25453 works with the included adaptor.  I prefer the DWE6423K mainly because of its a bit quieter but mainly that it seems to be a bit better in catching sawdust.​ Oh and i’d love a 20V sander.
 e I’d love to share a sid​e by side but for some reason I can’t upload pics anymore.
actually the D26453 has an adaptor that fits both 1 1/4″ and 2 1/2″ hoses but the fitting on the sander is different than on the newer model (the new model is round and the older model is more flat or tubular) so the adaptor won’t work on the DWE6423K.My 1 1/4″ hose on the 581H works on the D26453 but not the DWE6423K unfortunately. They do sell adaptors but not sure what the model number would be at this moment.Once I figure out how to post pics I’ll put some up so you can see the difference.
OK thanks, when I tried it said that I can’t upload the file, but I’ll try again/
If you want any other pics lets me know. As you can see the older model had a two piece dust collector. I’m not sure why they couldn’t bother to add an attachment with the newer model.
I’m guessing its the latter, the dust collector works good but using a vac will always be an improvement.
LastOfTheVee8sMember since Aug 2015
Looking to see something like this come to the 20v line
Seems like they ditched the attachment and included their Airlock system directly on the sander. This way you can connect the DeWALT vacs (that have Airlock) directly. Other vacs will need an adapter.
Yeah Mr Yellow all I can say for sure is the 581h which isn’t made for that purpose anyways does need an adapter.
Correct. The cordless vacs don’t have airlock so you’ll need an adapter.
rossi7xMember since Oct 2012
Tis true that the Li-ion Cordless Vacs don’t come with Air-lock adaptors, but unlike previous versions of Vacs, the Pipe is not glued to the end attachment, so you can unscrew it, and in turn screw on an Airlock adaptor..
I have done this for testing the New Sander, and even whilst testing the XR Mitre Saw..
I must say that its a bit of a nuisance to keep switching the Vac On and then Off, but it does work well on both of the above products…
The only downside to ‘retro’ fitting an Air-lock adaptor is that the on board tools suffer in direct connection with the Airlock main ‘barrel’, so you have to use the tapered ‘rubberised’ adaptor to act as the ‘go between’…
Never thought about that. That is an easy solution. Though like you said, you can’t connect the on-board accessories directly and it’s a bit of a pain to keep turning it on and off.
Still in the market for a 902M…sometime.
