Archived from the Tools In Action forum (FOR SALE). This thread is read-only.
Milwaukee Fuel ProPex Expansion Tool.
$300 OBO + Shipping
North Houston
What do you have in the kit? I could be interested.
Can you clarify? Not sure if you’re asking how much money I have in it or what is all included?
All that’s included.
Gotcha.
Two batteries, unit, charger, 3 heads (1/2″, 3/4″ & 1″) grease and hard case.
That’s a good deal, I’d pick it up but I have Viega tools
I’m thinking hard about this. as of now I’m using rings and crimping tool
Been there before. The ProPex (Type A) isn’t really that much faster per fitting, but I’ve had my fair share of crimped fittings not seal and going back and fixing is the downside.
I also like the fact you can smooth out links with a heat gun.
PEX A, does have its advantages that’s for sure.. Pull the trigger Regopit. Lol
Definitely a pretty good deal!!
A sign of a true tool addict, I want one of these just cause there cool….I do about as much plumbing as a painter…..
I feel the same way. I really want the Hole Hawg, but I can’t justify having it at all lol
You could put a paddle in the chuck and mix your paint.
Hahaha…..oh man you just made me spit up the wat we I was drink8ng. Just had this image in my head of the Milwaukee Symposium with some guy demonstrating other uses for the hole hawg. Thanks for the laughs manregopit wrote:
Thinking about it now, I think that’s a great idea
Now that’s a fantastic idea! If you want Ty dyed walls. Lol.
PROTOOLNUT wrote:
Cool tool, kind of expensive for pex pipe expander, I suppose its used after you’ve already crimped pex down. You can tell I know very little about plumbing but I don’t care, its not my field lol. I love Milwaukee though so I know that its a quality expander, however it works. I suppose Milwaukee makes a quality PEX crimper too? Let us know how you like it. And yes, I am sure that cone shape can be put to other uses as well. 😉
It replaces the crimp tool. It’s designed for TypeA PEX and fittings or often referred to as PRO PEX. You can not use this on your commonly available PEX from lowes or HD.
I was under the impression that you could use the standard fittings, just not the rings, as those were what the propex tool stretches for you.
You are correct. Any barbed fitting for PEX will work. It also requires a secondary sleeve made of PEX material to go in place of the crimp.
I always liked Wirsbo pex and the Milwaukee expansion tool I always wanted to try it out but we don’t install pex here. It’s only the horrible cpvc pipe or copper pipe. I think when pex first came out it was installed in new homes here and I heard it was recalled after the houses were built. But I never seen a house done in pex here so that could be why its not used today.
