Plastic Bucket Repair Ideas???
redmedMember since Dec 2014
OK guys, I have a bucket that is exactly what I want except I have had two and the bucket keeps cracking (at the red arrow). The first bucket cracked the first time I used it. I was careful with the second bucket and it cracked the third time I used it. Obviously the handle is way too weak and needs to be strengthened.
[Photo from the original forum is not in the backup]
I now have a another one of these buckets and planned to fill in the underside of the handle to strengthen it. I originally planned to fill the underside with silicon or liquid nail stuff. Now I read that it is hard to get something to adhere to Polypropylene. So far I have only found two glues for Polypropylene 3M Scotch-Weld DP8005 and Loctite Plastics Bonding system. Both are glues and would be to expensive to fill the underside of the rim. Any ideas?
Redmed, it’s hard for me to see the crack but can you heat it up with a torch to fuse it back together? Or maybe try JB Weld? That epoxy is fantastic….
khariVMember since Dec 2014
I used to have a plastic tub with a similar rolled rim that kept cracking.  I solved my problem by strengthening the rim with 1/8″ steel attached to the underside of the rolled rim with FiberFix tape.  I’m not sure how you’d get the steel curved to match the rim of your bucket, but it might be an interesting weekend project to figure it out or you could adapt the concept – reenforce with metal instead of just filling with epoxy.
