Ryobi Jigsaw – Bosch T-shank will not fit
tektMember since Jul 2013
I recently purchased the Ryobi P523 Jigsaw. I was going to use some Bosch T-shank scroll blades that I had used in my old Ryobi jigsaw on a project with my new jigsaw. Well, the T-shank Bosch blades will not fit in the new jigsaw and the specs list: For use with T-shank jig saw blades or Ryobi universal shank jig saw blades.The lock collar for the blade will not quite lock into place. The shank above the T is just a bit longer than the Ryobi blades I have.
So, I go to my local Home Depot in Raleigh and well, they don’t even sell Ryobi jigsaw blades. Really?? 99% of what they have is Bosch and then some knock off brand. Has anyone else had this problem? It seems to me that Ryobi made a boo boo with this and why does Home Depot not carry Ryobi jigsaw blades in the store? I like the jigsaw and it cuts great with the standard wood blade I have but I’m probably going to return this thing unless someone know’s something I don’t. I’m not going to order and wait on blades every time I need one.
I wonder if you got a bad unit did you try swapping it out? I can’t imagine them advertising it as Bosh t-shank compatible and then not being compatible. Bosch are the kings of jig saw blades really.
It says just T-shank compatible, not a particular manufacturer. Bosch just happened to be the T-shanks I had already bought and used with my old jigsaw. You’d think all T-shanks would be a standard size. I really like the Bosch blades! I may take a blade with me and see if it will fit in the floor model next time I’m up there.
I would take the blade in the store and try it on a floor model like you said and go from there.
Welcome aboard tekt. I’m with DR on that, I’ve never heard of t shanks being offered in different sizes other than blade length and thickness. A t shank should fit your machine regardless of manufacturer. Maybe the unit you have is defective. Additionally…my second to least favorite jig saw was the Ryobi with that adjustable scribe knob. Nothing but problems for me with that machine. But I may have had a defective unit too.
The Bosch shank from the top of the T and up is definitely longer than the Ryobi blade. Just enough that the collar won’t rotate quite enough to lock the blade in. I’ll post some pics later so you guys can see what I’m talking about.
Ok guys… Here’s a link to 4 photos I took. You can see the locking collar goes all the way to 90 degrees with the Ryobi blade and will only go to 45 degrees with the Bosch blade. (I thought maybe I could attach the photos somewhere but I couldn’t find that option) The issue that Ryobi may have overlooked is other T-shank blades are not universal and don’t have the U cut out like the Ryobi universal blade does.
https://www.cubbyusercontent.com/pl/Ryobi+jigsaw+blade+issue/_a04ff75a80634ea7be9f398e4bc7405a
Yea, that’s pretty weird man. I’d return it for sure, and I almost never return things
Mr RyobiMember since Feb 2015
My Jigsaw does the same but I have noticed that when you use Bosch blades it does turn and lock enough for the blade to work fine. Iv had no problems in the blade coming lose or falling out.
Thanks Mr Ryobi. I wasn’t worried about the Bosch blade coming out while using it, I just didn’t know if it would eventually damage the locking mechanism. I haven’t gotten around to it yet, but I’m just going to grind the tips off of my Bosch blades. I still can’t believe that Home Depot doesn’t even sell Ryobi jigsaw blades in the store.
I use my jigsaw nearly every day so hopefully it doesn’t damage the locking mechanism. The company I work for always supplies Bosch blades so I wont be buying Ryobi blades any time soon. I,m sure you could get them on line though.
FatManMember since Mar 2016
I found out the same thing. The locking mech does not close all the way with other t shank blades. I ground off the tip and still the same problem. I don’t know if it is the side tabs or the hole that needs grinding or drilling, but this sucks. Ryobi should be sued for false advertizing. t shank blades do not fit their saws.
khariVMember since Dec 2014
This is disappointing.  I was looking at the P523 as a stop gap until Milwaukee comes out with an updated Jigsaw (WTB an M18 with an LED and a blower…).  I think I’ll take a blade into the depot and see if all of the P523’s are like that.  If so, then I’ll just have to pass as I’ve got a bunch of Bosch blades.
ClearcreekMember since Apr 2016
I bought a P523 yesterday and learned the surprising fact that no blades for it are available anywhere in North America in any form!  When I pointed this out to a manager at Home Depot, he was aghast too.  This bureaucratic incompetence provoked the usual reaction for a guy like me, namely… I’ll just make the d**n thing!
It is not that hard to modify a normal T shank blade to work in the P523.  Message me if you want a pic…
Well that’s a kick in the pants, @Clearcreek what a let down, make sure you do your homework next time cheese and rice!
As a side note…….. WELCOME ABOARD THE FORUMS!!!
taylorv1Member since Jun 2015
I bought the new Ryobi Jig Saw earlier this week too, and bought the bosch blades, since thats all they had. Mine blades fit just fine. Just make sure to turn the quick blade release…
Jog saw blades can be tricky sometimes you have to make sure that you turn the blade release all the way and you put enough pressure to get the blade in, I always double check by try to pull it out then I aim at the ground and test to make sure it holds. Sometimes you don’t have it in all the way.
taylorv1 wrote:
Hey glad to hear you got it figured out, may be an isolated problem, time to make a video tutorial on this!!
Now I’m going to have to take a blade into the depot to try it out for myself on the floor model.
ApKMember since Jul 2016
Hi folks,
I just got the p523, and am also rather stunned at the blade situation.
It’s good to hear that Bosch blades apparently work safely even though they don’t “really” fit, but I’d sure feel better if the lock engaged properly.
Looks like you can order a set of 20 Ryobi blades on Amazon for about $50 or ebay for a bit less:
https://www.amazon.com/Ryobi-Rak-20Jb-Jigsaw-Blade-Set/dp/B006XBT0QK
But I’d interested in seeing how Clearcreek does the mod.
Not sure if I can PM yet as a new member, but if not, can you post about your process here?
Thanks,
ApK
50 bucks for 20 blades? thats nuts… that money add another 30 bucks and get yourself an entry level bosch jig saw
KatoMember since Jan 2014
I use Bosch blades in my Ryobi, and I have no issues using them. If they don’t go in far enough to satisfy me, I grind off a bit of the shank and they fit perfectly.
When I had my ryobi I never had issues with Bosch blades, that’s all I buy
They won’t go in all the way, but most of them go in far enough that they can’t come out. I’ve had one so far that I had to trim down, otherwise Bosch blades have been fine. I haven’t investigated the jigsaw yet but I’m sure there’s a way to modify the receiver so that the Bosch blades set further. Probably something as simple as trimming a spring or some other basic fix.
That crazy there’s no way I’m modifying the available blades to fit the unit. That jig saw would be going straight back to depot. As the Home Depot brand Ryobi should 1000% be compatible with the blades Home Depot sells. That is a huge let down from ryobi’s design and research teams
Home Depot has no obligation to make one brand compatible with another. Being a “house brand” doesn’t mean shit, Home Depot sells it, they don’t make it. Seems to be a common-sense thing, Bosch makes accessories to fit Bosch tools, Ryobi makes accessories to fit Ryobi tools. If one fits the other then it’s a win, if not, you come up with a solution
It’s not crazy at all. Performing a simple basic 30-second fix to resolve an issue…isn’t that what guys do?? I mean come on, you’re on a tool forum…
I don’t know, maybe it’s just me, I don’t have any problems coming up with solutions to basic issues. I’d rather fix it if it’s a minor thing to do, I wouldn’t even consider this an issue at all given the fact that it’s such a simple solution. Either you fix it or you buy the blades that are branded to the jigsaw. Your gripe is with either Ryobi or Bosch, if they make claims that they’re compatible then it’s their fault. If I were at all upset that blades didn’t fit, I’d buy the blades that Ryobi makes.
BTW, I don’t think this was intentional. By the looks of Ryobi’s blades, I think they were going for being able to accept U-type and T-type blades but they made assumptions about Bosch’s blade. Just my opinion BUT…
I think we need to be vocal in this situation, this can set a poor example and lead to very frustrating “innovation.” We’ve had to accept it if you’re an Apple phone user, the only phone that needs a specific licensed proprietary plug. Imagine if Ryobi doesn’t get any negative feedback from this and that this helps Ryobi blade sales. We already sort of see it in oscillating multi-tools, luckily some manufacturers have come up with and include adapters. From a brand’s viewpoint, it benefits TREMENDOUSLY if they can sell proprietary disposables for their tools but no one will buy a reciprocating saw that can only use one type of blade…unless we start telling them it’s okay and everyone starts doing it. It’s not working in this case, and that’s a good thing. We’d know i it was working because Ryobi jigsaw blades would be carried in HD by now.
Especially since that 30 bucks can come by buying 20 bosh blades for 20 bucks instead.
Don’t forget you get that nifty case too.
Anybody try a different brand of t-shank yet? I’ve used Bosch so far, but I’m curious about DeWalt and others, if they’d fit better or worse.
jswoger1986 wrote:
I agree, and normally, I’d be returning it and switching brands, but I’m happy with all my other ryobi one system stuff, so I have several batteries.
Plus so far I do like the jig saw itself, so as long as I can trust the Bosch (or other available t shank) blades, I’ll settle for merely sending ryobi an angry letter.  But I’d really like to know the Bosch blades are safe when locked only as far as that 45 degree position.
By the way, any one have an opinion of Rigid blades?  They appear to have the same ryobi universal design.
I believe HD owns Ryobi.  Either way, you’re certainly right that it’s ryobi’s fault if they claim t shank compatibility but don’t deliver it, or Bosh’s fault if they claim their blades are industry standard t shank, but they really aren’t.  But it’s also HD responsibility to deliver a good customer experience in the stuff they choose to sell, and this isn’t one.
People shouldn’t have to make another hobby out of modifying blades to get basic functionality.
ApK wrote:
You are mistaken. Ryobi is owned by TTI…Techtronic Industries. Home Depot is a store, a distributor, not a manufacturer.
Kato wrote:
Meh.  It was probably an HD employee I’d heard it from so I’m not surprised that it’s wrong.  Still, sounded plausible.  Sometimes companies buy other companies to control more of the supply chain.
Anyway, point was just HD should sell compatible blades.
Sure, because we all know that the employees at Home Depot are geniuses, brain surgeons and think-tank representatives. [External image (i15.photobucket.com), not copied]
Home Depot does sell compatible blades. They sell Bosch blades for Bosch jigsaws, Dewalt blades for Dewalt jigsaws, etc.. Return the blades you bought, try a different brand. The Bosch blades I use, some fit halfway, some fit further in, some don’t fit further in. The ones that fit halfway and beyond I use with no issue. The ones that don’t go halfway, I trim them down so they fit.
Anybody who claims that one brand fits another either does so because it’s true or because they’re morons. Either way, I take the necessary steps to make sure that the accessories I use are compatible with the tools they’re meant for. If that means making a simple adjustment, I do it. If it means trying a different style or type of accessory, then that’s what I do.
Takes me about 2 seconds to drop the angle grinder down, another 2 seconds to slap a battery in, and about 5 seconds to trim the tip of the blade down. Given the alternative, wasting a lot more time going to the store to return the blades and get different ones…I’d prefer to make a simple adjustment and carry on. I understand the frustration but it’s just a jigsaw blade, a thin piece of metal that can easily be modified. You don’t want to do that, cool, no problem, I understand. Me, I just take the path of least resistance, it’s easier, it’s faster, and it doesn’t cost me any money or stress.
HD has merchandising rights with TTI resulting in sales of Milwaukee, ridgid and ryobi
For the record, I’ve been test cutting with the Bosch blades (lock only going to the 45 degree position) and have not had any problems, so I’ll probably just continue to use them unmodified, unless a better options presents itself.
BTW, grinding the insert end of the shank to match the Ryobi blade does not improve the fit at all.  I suspect the difference is in the width of the T tabs, but I’m not interested in more experimentation right now.
Dan A..Member since Oct 2016
I HAD THE SAME PROBLEM WITH MY RYOBI JIG,  FOUND A GUY ON YOUTUBE WHO FOUND THAT RIGID TOOL SELLS A REPLACEMENT BLADE .  YOU CAN BUY THEM FROM HD IN A 4 PACK, AT HOME DEPOT ON LINE FREE SHIPPING TO STORE.
KBDMember since Feb 2017
Ok so slightly filing the T on the Bosch or sears blade (both sides) will allow the blade holder to fully clamp into position.  The Ryobi site told me in my inquiry about this issue that a partial clamp on the Bosch or Sears blade is adequate, However since I cannot visualize how this actually clamps the blade in place instead of fully closing as on the supplied Ryobi blade I question that in hard use that the blade holder may become compromised as it is constructed out of some type of plastic.  You would think that Ryobi would slightly redesign the blade holder to accept the more prevalent blades that are on the market.  I ran into a similar type issue when I purchased a new ryobi drill that has an led work light, which is a great idea, however it does not come on until the drill is actually moving which renders it virtually useless.  Now I will say that the cordless sabre saw in question (p523) is a really nice unit with tons of power and speed and other features. Just wish the blades fit.  I also have not been able to find Ryobi blades for sale at anything other than ridiculous prices.
KwalkerproMember since Feb 2017
The Bosch T Shank fit perfectly fine in the Ryobi jig saws, there is just a little trick to get the twist collar lock to lock.
When you turn the collar to its open position and insert the Bosch t shank blade I and release the collar it looks like it will not engage, but at this time push the blade in and you will feel almost a springy feel and then the collar releases and locks the blade into place.
It works, just need to know this trick.
Hope this helps.
kwalkerpro
LighteningSamMember since Jul 2018
This is what I did that worked. You can see the problem in the image. Grind both tabs until “almost” as narrow as the Ryobi. This is probably why it fits some and not others… the Ryobi is marginal and each Ryobi is a little different. Guessing, I would say the BOSCH tab is 75% wider than the RYOBI. Photo from the original forum
There is supposed to be only one size T shank. I am pretty sure Ryobi did not set out to make a unique blade that just fit their saw. That makes no sense. Somebody screwed up in engineering or manufacturing. You can maybe fix the tool, definitely modify other brand blades or take it back. Ryobi screwed up. I doubt contacting them would do any good but he could try. I would return the tool and get something else. It may not be HFs fault but they are most likely the one to provide a solution. They are selling a T shank tool that does not accept any T shank they or hardly anyone else can supply. I do not buy the argument that it is only required to work with Ryobi blades. A T shank is a T shank.
AnniesellsgreenMember since Mar 2020
I’ve been messing with this stupid Ryobi jigsaw for over a year trying to get blades to fit. I’ve had the Bosch blade fly out in the middle of a job. I now wear leather gloves. It can’t be trusted unless the lock mechanism turns the whole way. Also the 25$ kit of Ryobi blades on Amazon does not fit the saw. Ryobi really does need to be sued. I’m not rich enough to buy another saw when all my batteries are already Ryobi as all my cordless tools are Ryobi.
BrendanMember since Mar 2021
In my efforts to cut out an insert for a sink into a high gloss IKEA worktop, I came across this discussion.  My old corded B&D jig-saw doesn’t take t shank blades, and most of the DIY shops near me carry Bosch blades. I’m not a professional, so I was just looking for an entry level jigsaw.  I have a couple of newer Ryobi 18v tools and a Bosch 18v drill. Due to age differences the Ryobi has bigger batteries (I think you need at least 3aH and easier if you have two of them!  Reading this forum I was a bit hesitant but went for the Ryobi R18JS-0.  I found a pack of blades that included a some reverse teeth (RAK05JSBFC), and I also bought a pack of 3 Bosch (T101BR HCS) blades – again the reverse teeth again good for cutting laminate from the top.
I know the original discussion is old now, but I can say both blade types fit with no problem, and I appreciate the ease of changing blades provided by the newer mechanism.  Used masking tape on the worktop, and did a practise drill (10mm wood bit, but you could start with small 3 mm if you’re worried about skipping) and cut in the waste portion, no problem.  Drilled 10 mm holes in the corners (white high gloss ceramic is tough, but OK once you get a few mm in). I did half with a Ryobi blade, which was OK but felt difficult and you could not go quick of course (40 mm worktop).  Swapped to the Bosch blade and that was noticeably easier on the cutting, although you could feel a little more kick.  I took advice from other posters and did not bother with guides or clamps for the sink insert, just concentrated on the cut and the line in the tape.  No problem with chipping and the job looks good.
sanchez040Member since Dec 2019
Yeah, I can also confirm that Bosch T Shank is maybe the best choice for the Ryobi jig saws.
FinnMember since Jul 2021
Bosch blades work just fine, you just have to make sure its inserted all the way. You have to push a little harder to insert Bosch or Diablo blades then you do with the blades that come with the ryobi jigsaw
