Christmas Gone by Yet ….1 more gift……
ok so had to do 1 more a little different playin with some patterns…..
this one is made from black ash and South American Purple Heart….
Nice job Comp! How’s the Purple Heart for cutting?
cutting and sanding is a bitch, reason being is while cutting if you heat up the wood any amount a gumby like resin comes to the surface and is almost black…….once this is visible it is almost impossible to remove .as for sanding it is like sanding concrete…….you pretty much have to use a course grit and don’t let it heat up as you will end up with same problem……another thing about purple heart is the fresher the piece is cut from the tree you can get the more purple it is ……..UV rays turns the wood dark brown so even if you make something you must seal it with UV protected sealant or it will change color. the piece I made is more purple in person than the pictures show….
Thanks for the advice Comp, I saw a slab of it at Woodcraft. It was beautiful. Crazy dense though. The piece you made is quite beautiful. Good work dude!
Really cool! How do you apply that pattern, I’m gonna call it zebra, do you lay a stencil over it and spray the dark stain or is it all hand done?
Nice job comp.
Very cool comp!
That is pretty cool looking. It sucks that the wood is difficult to work with though.
thanks for the comments, ya like anything a little practice with a test piece goes a long way…….I do many projects with many kinds of woods.
I always buy more than I need, I always use a small piece and try stuff with it to see how it reacts….some times what works with some types of woods don’t work with others….
the zebra style is stain right. you prolly used a template to apply the stain to get the zebra pattern
yes I did and yes it is stain, I have a vinyl cutting machine, so I just make a stencil, stain, remove ……sand with 000 steel wool and a few coats of polly 000 steel wool sanding between coats….I use oil modified so coats are about 10 minutes or less apart…
Up here it’s so cold, the stain would freeze before it dries.
