I-socket
Kegger1986Member since Dec 2014
This isn’t a dewalt tool, and I’m sure most you guys have either bought one or heard about. But it’s a sweet little 110v Plug and you can hook up your power tools to and a vacuum. When you turn on the tool the vacuum comes on as well and after the tool shuts off the vacuum will run for 7sec and shut off.. It’s called the I-socket, I bought one and love it!!!
Had not seen this one, need some photos.
good little gadget
CharlieMember since Aug 2013
The DWV012 has the switch built into it.
That’s a nice feature to have if you’re already invested into a solid setup and don’t want to change vacuums.
roadhog96Member since Jan 2011
Did you see this version, a little more money but the nice thing is you have 2 separate lines, 1 for the saw and 1 for the vac this way you won’t overload the circuit. You would need to run 2 extension cords to 2 different curcuits. Vac turns on and off the same.
http://www.woodcraft.com/Product/149950/iVac-Automated-Vacuum-Switch.aspx
Yeah I found that after I bout mine… But got one on the way, but I have not had any problems with mine yet.
