Did the fist oil change on the Chevy Cruize. It’s only a lease so I wanted a cheap and easy solution.
I did it the easy way by using one of those vacuum extractors for the oil. I just didn’t want to deal with crawling under the car plus this car uses a cartridge filter that you just have to replace no metal oil filter to spin off in a weird spot this was super easy to get to on the Cruse The only thing that made the job difficult was the weather it was in the 50’s but the wind was kicking at 30 mph. I usually just pay a shop to change the oil but when they wanted 40 bucks for a semi synthetic oil change I just flipped I was able to get the 15000 mile Mobile One Oil, and filter and it cost only 10 bucks more not counting the rebate I will get. I’m all about a once a year oil change we don’t pile on millage with our cars. If you just went by mileage I bet I could eek out 20k and not have to change the oil again on the lease if I was that cheap. I figure once a year is good enough. I will say the vacuum sucker worked awesome no mess really and didn’t have to haul out ramps or a jack and stands. The only thing is the shitty weather has made my cold feel worse I have been working through it a little too hard.
Joe MMember since Apr 2013
I have a chevy cruze too. It was my first new car purchase and I am only $500 more dollars and I own it free and clear. Figure I would drive it through college. It is not a bad car, not the greatest. I do find myself lusting over a Ram 1500 regular cab.
Brandon708Member since Mar 2014
Sucking out the oil and not replacing the oil filter is not a good idea. I used to do all the oil changes myself until i got tired of it. I think it’s worth bringing it in and having them do it for $40 and be done with it.
I did replace the oil filter its only 8 bucks and I was putting 40 dollars worth of oil in. I was just saying it was different that most cars I have had before with spin on oil filters. People over change their oil anyways people still do 3k oil changes unless your using some horrible cheap dino oil its just not worth the cost.
I change the oil on my truck every 3k miles. My truck has a lot of miles though.
Our local Auto Parts store is so damn high I can have it changed cheaper than I do it myself.
They probably use cheap oil. We always grease the front end of our trucks as well. I doubt the shops do that. Modern vehicles might have only two or four at the most.
Costco or Walmart is usually the best place to get Mobile one. Mobile guarantees this motor oil for 15,000 miles or one year, We don’t drive many miles, so it will save some cash long term. This is a pretty interesting article http://www.edmunds.com/car-care/stop-changing-your-oil.html. It says gm computes oil life to driving conditions, but all of the gm vehicles I have had the oil change light comes on at 5k miles. I liked the idea of sucking the oil out through the dipstick, and it did get all of the oil out I compared what you needed to add to what was sucked out and it was equal for the most part. I just don’t like being under a car with a jack and jack stands I start to get claustrophobic.
My Dodge pops on at random times. Typically between 7 and 8,000 miles.
JavierMember since Aug 2013
Cool I didn’t know you could suck it out
Its how you do it on most motor boats as the oil pan and plug is too close to the hull to get at to drain the engine normally normally. It was a really nice and clean way to do the oil change.
yamatitanMember since Oct 2013
I change mine every 8k running mobil one.
