Shed Project
Brandon708Member since Mar 2014
Last summer / fall I was making some improvements to the outside of my house that me and my buddy where doing. The main item being LP Smart Siding the whole house. We finished the job which came out pretty nice but we have a crap load of siding left over. So, I was “forced” to build a shed to use some of the siding. I wanted to build my shed to look very similar to my house. I designed the shed on my computer to get an idea what I wanted it look like.
I asked my village what the codes where for a shed size before being taxed. They told me 144 square feet and not installed on concrete pad. So I did my shed 10’x14′ (140 sf) and installed it on a gravel bed.
I started this shed project in December of 2013. The first thing I had to do was to excavate and level the ground. I then made a rectangle bed made out of 6×6 pressure treated post 2 high for the gravel and a total dimension of 12’x16′. I then laid down some weed control fabric and then 2.5 square of gravel and compacted it. Then built the shed on top of that including a wood floor built out of 2×8 framing pressure treated boards.
The rest you can see in the photos.  Very soon when this weather gets better I will stain the bottom flooring and 6x6s to match. Also, I need to install gutters and paint the blue roll up door black.
Here are some photos. I should of took pictures of everything but I really didn’t think about it till we got the framing up.
[External image (img.photobucket.com), not copied]
-Brandon
continued…
This last photo is a side by side in my computer program. The right photo is a real photo of the shed and the right is how I originally designed it in my computer. It came out really close to my drawing.
JavierMember since Aug 2013
Looks impressive. It has a nice color scheme
Great job. I really like the roll up door.
BrienMember since Dec 2013
Yes, where did you get that roll up door?
Did you build the door to the shed specs or did you build the shed to the specs of the door?
Great job!
Thanks, I really like the color too. I’m more into darker houses. My house is the only house on the block or in a good size radius that has a dark color.
Roll up doors are much better option for a shed and very simple to install.
Great job!
I got the roll up door from a guy on Craigslist. I only paid $80 for it and i also paid $80 for both windows. He had some left over from a storage building job. If you want to order one from the manufacture it can be found at www.Janusintl.com
I built the shed to to match the design of my house and I knew I wanted 8 foot walls so fitting the door wasn’t a problem. I just made the opening to the specs for the door. I also bought the door around the same time as I started to design the shed so, yeah I worked it in to the design. This door is good up to a 9′ tall opening but you can use it for any height because the door is just coiled up in the roll so you just don’t pull it all out. In the spring I’m going to paint it and add a Liftmaster 8500 with a digital key pad on the outside to open the door. I think it will help when Im in the backyard and don’t have my key on me for the padlock.
Really like the design.  I could live in that!  Really cool.  Very well done!
Thanks Harold! It’s kinda like one of those tiny houses.
Looks nice Brandon.
Could make that a nice man cave. Or atleast you have some where to stay over night when you get into an argument with your old lady
Nice job Brandon. Love the pergola over the slider and the cupola.
Nice shed brandon! Gotta fill it with tools.lol
Wow, that looks amazing! I Hope your painting the roll up door though the blue clashes pretty bad with a really pretty building. It reminds me a lot of the New Yankee workshop building.
[External image (www.woodworkersworkshop.com), not copied]
That was a discussion we had while building it haha. Although I really need it for yard tools and all the extra crap taking up space in my garage.
Those where the two little additions I made to make it kinda unique. I also have the pergolas over a large window in the back of my house and over the garage door in front of the house. I really wanted it to match the house so I added it and it worked out pretty good. The cupola is an addition that I did for my wife because she loves pigs and I wanted to incorporate copper some how so it worked out pretty good that way. It also is a functional cupola that ventilates the shed.
Thanks! I am going to be painting the blue door in a couple weeks when we get better weather. I really like the New Yankee Workshop but I don’t see the resemblance. haha. Unless you are talking about the other building when he built a cupola on it. That was a good episode. Thanks though.
I think its the general color scheme is somewhat similar between the two even though you have darker trim.
Yeah, I can see that.
I just started the other day to put up plywood on the interior walls in the shed. I need to order 8 more 4×8 sheets to finish it. Then Im going to start building tables, loft storage and shelves.
Matthew WiswellMember since Apr 2014
Wow! You did an amazing job!
I really want u o come over to my house and build one for. I like sliding door on it.
Brandon that came out sweeet!!
Nice job, I like that roll up door idea as well…….
roadhog96Member since Jan 2011
Nice job with that shed especially with the design and framing. I hate the way those sheds that those home centers carry are framed. Yours is done right like it should be, strong just like the house. Hey what’s up with your neighbors white house, is that painted graffiti on the siding?
Awesome job Brandon. Looks beautiful and the raised beds came out super nice!
So Brandon, are you going to use this as a shop or a shed? My shed is roughly the same size but truthfully for woodworking it’s not big enough for me. I’d imagine for spinning wrenches it would be great but handling sheet goods in mine isn’t easy. That really came out nice though!
Yea my shop is not huge , I have to open windows on both ends to handle long items.
Looking nice!
I like your saw 😉
I agree about the big box store sheds. They are flimsy and not built correctly and not what I wanted. I actually modeled the shed after the house and they are pretty similar. And yes it is a penis spray painted on my neighbors garage. I’ve been wanting to scrub it off but I haven’t gotten to it yet. I think for him its out of sight ,out of mind.
This is being used for storage shed. Mostly for all lawn and gardening tools, equipment and materials. Also store bikes in there during the winter. I have a pretty big workshop in my basement/garage. Having this shed frees up a lot of space in my garage. About the raised garden I am pretty excited to get it started in the spring. Also gives the wife something to do outside too. I do have some pictures of the tables, shelving and loft I built inside. Ill try to locate them in my phone and post them so you can see the layout.
hathatylMember since Sep 2013
Very nice Brandon!
that’s badass Brandon!!
Awesome, I was wondering when we were going to see the inside.
Great job. what do you use it for? Work, storage?
ya don’t think it but when you get enough bikes for the whole family they take up a lot of real estate
I use it mostly for storage. But In spring, summer and fall I will use it to tinker and for gardening purposes. I also will work on lawn equipment in there or what ever else I need. I have ample work space in my garage for everything else.
Yeah, You get 4 bikes and it takes up a lot of room.
Absolutely love that Bramdon….I’m stealing your bike idea…my wife and I have two road bikes and I’ve got a free ride mt bike that are taking up valuable space. Never crossed my mind to do that with the ceiling.
Excellent job! This is really something to be proud of!
