charging issues
stolisMember since Dec 2013
I recently bought the DCF895D2 impact driver witch comes with DCB101 charger…the problem is here in Europe I can’t charge the batterie packs…will I be able to use the DCB105 to charge???
The battery packs are DCB203…
It will work fine your just swapping chargers for one that runs on European voltage the battery pack does not care either way.
Gatorb888Member since Nov 2013
I believe DR99 is right, US Batteries should work in EUR chargers and vise versa.
The voltage coming into the charger shouldn’t matter because it will have to drop to 18 volts.
should work???
what’s the DR99 ???
so using the DCB105 charger for DCB203 batteries will be safe and do its job right???
is it for sure cause im about to buy one…
I’m DR99. The connectors and voltages are the same the packs are chargers are all interchangable all you need to worry about is the line voltage and connector for your country.
JavierMember since Aug 2013
You should listen to the DR it’s good for you
Thank for the info and help..
