New Forum – First Post
toolsinactionMember since Dec 2010
Hi everyone, we are working on updating the forum.  Hopefully you will enjoy the new changes.  Post any issues here.
Needs more yellow 😉
We are working on the look :}
Mr. Yellow wrote:
Needs more yellow 😉
Say’s Mr. Yellow, haha
Looks great, I’m excited about the new look!
BrienMember since Dec 2013
I turn my head for one second and this is what you do to my Forum!
I fear change. I still run 18V nicad dewalt batteries, I still have a flip phone, my car has a cassette player and Miami Vice is my new favorite show.
Change can be a good thing. Only time will tell as always huh? Looks good.
looking forward to the changes!
not sure if its me doing something wrong but when i click on a topic on the full site version it always takes me to the first origional post in that thread.. on the mobile version it remembers the last post i read and brings me to the most recent post that i havent read..
this isnt a new problem just something that has always been since i started here.. a minor fustration.
is it me or is that the way the full version works?
if thats the way it is, is there anyway to make it act like the mobile version?
let me know if i wasn’t clear, ill try to re-explain
Thanks guys, keep up the good work! TIA kicks ass
hey, for the first time ever i just hit a limit of “likes” per day    is that a new change or something that has always existed?    what is the limit?
cant wait to see the new changes very exciting!!! T.I.A!!
I can’t wait to see what’s in store. Brien you r hysterical. As far as problems, pictures, not enough yellow, I think new registers 1st post should be introduce yourself, I have to post a post- then edit in order to get emoticons to show up on post. Also if not the one creating a post, I have to post then edit to add photos, post counter.
Oh and giveaway winners should be up near top next, UTB giveaway.
More….MORE….Yellow?!?!?!?!?!!? How’s about some Blue and Green? How’s about some Blue and Red? My God in Heaven!!! I know I just added a bunch of yellow to my shop but cmon!!!! Give an under cover brother a break!!!!
LMFAO!!!
In all seriousness, I think we are going to have a lot of yellow coming out from dewalt. Dan and Eric r going to be very busy.
changes? oh sweet – cant wait to see them.
how about a Bosch Main Thread; I would hang out there all the time and keep posting stuff
Madman we didn’t realize u like Bosch. Maybe we can get u some help.
WillyGMember since Feb 2015
HI, This is my first post and I hope someone can help. I’m repairing a dewalt framing nailer, #d15844. The tool started to blow air out the front and quit driving nails. I ordered an o-ring kit and installed the new o-rings. The kit did not contain o-rings for the trigger assy., but after inspecting the assy., the o-rings looked good, as did the plastic assy. No cracks noticeable, and I reinstalled. After assembling the tool, and applying air pressure, all air leaks were repaired, but tool still will not drive a nail. Tool gives a “puff” type sound and seems to be moving the hammer, but not enough to even start to drive a nail. Now, I’m suspect of the trigger assy. It seems to not be moving as freely as it should, but will cause the tool to fire. Also, after removing the “exaust assy” from the rear of the tool and applying air pressure, air is excaping out the inside on the handle. Is this normal, or is the trigger assy not working correctly? This trigger assy cost around 40 bucks and I don’t want to spend money on a part that is still good. I hope I have explained the problem clear enough so someone will have an idea how to fix this tool. Any help will really be appreciated. Thanks, WillyG
Hey Willy. While I’m not familiar with that particular gun I have rebuilt several framing and roofing guns over the years any typically the o-ring kit solves the problem.. are you position very everything going went back in the correct order?
Also is it cold out where you are? Nail guns don’t like to work when it’s cold out.. leave the gun inside overnight somewhere near a head source and check it again the next day.. did you verify that there is no issues with your air hose and that your compressor is supplying somewhere around 100psi??
Hey John: Thanks for the reply. The air compressor is putting out about 120 lbs. And yes, its really cold down here in Hartwell Ga. Around 18 degrees today, but thats not normal for here. Would you know if the trigger assy. is susposed to cut off all air to the gun, in the neutral position. Now, the gun is passing a considerable amount of air passed the trigger assy. This does not seem normal to me. To me, at least 1/2 the air pressure is being used up before the trigger is pulled, whice does not leave enough air pressure to fire the driver. What do you think?
Its hard to say exactly..  18 degrees is definetly cold enough to start making a gun act up, when they are cold they tend to leak air and not fire.. my guess is that the o-rings inside contract due to the cold and let air leak past (just my own hypothesis though) due to cold,  i have had guns that just continuously leak air when they are plugged in and also ones that make a air leak noise only when you attempt to fire a nail..   i would say before you do anything else to the gun let it get good and warm inside and then test it .. hopefully its as simple as that, if not then the trigger valve seems like the next reasonable guess.
good luck!
whenever im framing or roofing in freezing temps i always leave my guns inside overnight and bring them in durring breaks and  lunch   that seems to help for me
help? nobody can help someone who is infected with the TIA disease – specially with this crew who talks you into new tools
Madman, nobody has to convince you of buying new tools!!  you do a damn good job of convincing yourself 🙂
ppsssshhhhh i try to point fingers at the others that i dont have to feel “so” bad lol
ahhhhhh i get it 🙂     glad to be your scapegoat
just had to look up that word lol
Learn something new every day!!
Madman, it’s the diseases fault.
Thanks, I really appreciate the Info!!  Will let you know how it comes out!!  WillyG
anytime!
NEW DCF 899 P2 / DCF 899 HP2
just out ; a bit of surprise
April 2015 started Q2 for DeWalt in Europe also with the publishing of a new “quarterly Brochure” with new Product introduction
as always all PDF Q brochures are available on country specific dewalt sites;
hence, new Q2 brochures on sites of Belgium, France, Poland, Netherlands, Germany, etc..
nice to check these sites, because there are always country specific introductions
now to my title:
now in Germany available the new impact wrech (18V / 20V Max)
Supreme Power 950 NM
P2 just means Kit with 2x 5,0Ah batteries
more news to follow in different posts
cheers
mike
thats a really powerfull gun
Nice!!!
honsesMember since Jun 2015
its hard to say Im new to the site, but been watching the youtube channel for some time, I like the mapping on the forum, great job
Welcome to the forum @honses !
Welcome aboard honses!!
Turner85Member since Jun 2015
Just joined the forum after stalking it for the past couple of weeks. Recently bought into dewalt just by chance when I was in a hurry for a new set of drills. 2 months later I’ve got there toughsystem with trolley, the dcn692 nailer and dcs355 multi. Next on the wishlist is the dch274 as I am looking to purchase all the brushless gear first in the hope they re-release some of there brushed stuff in brushless versions. Also hyped for some of the new tools I’m hearing about this week.
Turner85 Welcome to the crew bro!!
Welcome Turner. Glad you signed up. Stalking is all good but participating is so much more fun and makes the forum better for all of us. Looking forward to what you have to share
Thanks for the welcome lads, although I’m 14 years in construction I’m only really starting to take it serious. I’ve owned a lot of tools over the years but never done any research till this year and would always just buy a mixture of brands and generally it would be makita as it was what my local suppliers always stocked. Well now I’ve made the change to dewalt I’m slowly selling off my old tools and investing in newer up to date tools. I’ve also just bought myself a new van, 2009 ford transit and am hoping to build myself some racking to integrate my toughsystem boxes, so I will make sure to let everyone know how that goes.
Welcome aboard Turner85! You should talk to NER and KWC about van set ups.
rossi7xMember since Oct 2012
Here’s a link.. http://professional-power-tool-guide.com/power-tool-forum/index.php?/topic/3296-tough-box-racking-in-my-van/?hl=%2Bdewalt+%2Bracking
and here’s another for ideas on the Van racking…
http://professional-power-tool-guide.com/power-tool-forum/index.php?/topic/2762-my-tools-toughsystem-racking/page-2?hl=%20dewalt%20%20racking
If you need any other ideas, I’ve got a few more shots of other Vans that have done  in the UK too…
Thanks again, I’ll be sure to look over the links and I’ll take some photos of progress. I’ve to finish plying it out first which I should get done early this week if time allows.
