A LOOK INSIDE THE DEWALT DCB204 4.0ah LITHIUM ION BATTERY
kanxrusMember since Jan 2009
HERE IS ANOTHER LOOK INSIDE.
bungeeMember since Nov 2011
I take apart mine DCB204 – it was with green cells, but i am not sure about the model… Mine is from Home Depot, coming from Dewalt DCF895-M2 kit.
What is the brand of the red cells?
tooldevilMember since Nov 2009
Hey Bungee,
it looks like a Sanyo / Panasonic cell, if you google the No. that is printed on the cell, you will get a lot of information about the cell and the cell suppleir, I hope that helps
Cheers
Tooldevil
These are the Sanyo cells. Interesting that you would find green (Sony cells) in a DCB204. I have yet to see a single Sony cell in the slide pack batteries.
bulletheadMember since Dec 2013
 my XR 20v tool has 4x terminals, 2 are negative & positive, the other 2 appear to be sensor wires (yellow/brown) (second from left & second right on battery top row) they go into the board (resin moulded) and back to the switch that powers the tool, what is sent from the battery via these two wires and how?
I plan to run Lithium Polymer batteries (with built in protection) so need to supply the correct votlage/current to these wires so the tool will operate
any help here greatly appreciated!!
simojokerMember since Feb 2015
I need the same information, have you find it
William SMember since Jul 2015
any reason you are going from ion to polymer? I mean what are the advantages you will gain from polymer over ion?
Bdwlf2Member since Jun 2016
I was thinking about replacing the batteries with either LG-HG2 18650 batteries with a 20a discharge and 3000mAh capacity, or the Samsung 30Q 18650 batteries with basically the identical specs. (Samsung rates the 30Q as 15a, but testing shows that it handles 20a without breaking a sweat.)
Anyone see any problems with doing this? This would make the DCB204 battery sled become a 6.0ah battery instead of the 4.0 stock. Also would give it a better discharge rate so the batteries won’t overheat as quickly.
Just asking if I’m correct in my assumptions and should carry-on with my battery upgrade.
Any and all advice is welcome.
Not sure how their electronics are with their batteries, I would just be careful, I’m not sure how they program their tools with overload protection. So swapping cells may not benefit at all if the chips limit it to the capacity of a 4.0 battery, it’s a great question though I hope that it works.
kdobrevMember since Jan 2017
Does somebody now know what each terminal of the battery is sending to the tool?
Cr8ondtMember since May 2016
kdobrev wrote:
b- and b+ are power, th and c3 are for the tools overheat sensor c1-4 are for balance charging and im not exactly sure what id is for
