Dewalt DC925 xrp
macka001Member since May 2012
Hi, Ive had the DC925 XRP 18v cordless drill for a few years. yesterday went to select the hammer function, and the coller does not go beyond 1 or 21 so i cant select normal drill or hammer action. any ideas?
drill works fine apart for this issue.
Thanks
deedub35Member since Mar 2010
This happens to my DC988 sometimes.  Also the speed selector sometimes doesn’t change easily.  I pulse the trigger and change from forward to reverse and back a few times and then try.  Usually changes after a few tries.  I’m wondering if there is something that is not lining up properly in the gearbox.
jevinkMember since Oct 2010
I had this problem on a DC988.  I just got one of those rubber strap wrenches and put it around the dial, and cranked it til it turned over to the hammer mode.  Worked fine after that.  Might not be the most professional way to fix things but did the job.
SoloMember since Jul 2022
How do I remove the blade ?
