My DW321 Jig saw does not have scrolling capability, but lately the blade turns as I’m cutting. As there is no scroller knob to control it, the saw is virtually useless. I have the parts manual, but before I dsassemble it to see what needs to be tightened or replaced to hold the blade true, I thought I’d ask if anyone had this same problem, was it fixable, and what is the fix.
Thanks.
DWdiyer
I am not sure, just call up a Dewalt service center and ask them. They will let you know over the phone.
Service centers can be found here: [url=http://www.dewalt.com/Find-Service-Center.aspx]http://www.dewalt.com/Find-Service-Center.aspx
Thanks, but I tried that, and the associate suggested I have the saw serviced, which was quite clearly not worth the expense.
Just out of curiosity, what type of blade are you using? U, T?
I just spoke to a service center rep about this issue. Sometimes the blade clamp can get damaged when using orbital action in hard materials like Metal or hard wood, causing this problem. The service center can replace the clamp assembly for you, and that is the only way to fix the problem. They will also be able to tell if the problem was caused by missuse (using orbital action in metal) or if it’s a manufacturer defect. That will determine whether it will be covered under the warranty or not. If it isn’t under warranty then it should be under $40 to replace the front assembly.
FYI.. Lowes has the DW331K on sale right now for $149. Was $169…
I have had the same problem- I am so disgusted with this jigsaw-!! I am off to buy a new one today. I like DeWalt tools, I have so many- I am going to purchase the DeWalt DC330B – I hope that this will be a better jigsaw- I will let you know-
I could never keep the blade to stay in the jigsaw while it was operating, cutting wood- I had the guy at Orchard look at it, my brother, my neighbor- they could not figure out the problem??
Are you using a T-shank blade or the U-shank blade? It needs to be a T-shank to stay seated in the chuck.
I simply threw mine in the trash.
I had the same issue with the blade not tracking.
blade changing is also quite odd. You never know if the blade is locked in place. When the cheap front housing broke off that was enough for me.
