Archived from the Tools In Action forum (Ridgid). This thread is read-only.
So the other day the screw with its 3 washers blew off the bottom of the arm that operates the rotating guard on the saw. I have know idea what order these washers go in so I just made it work ! You really don’t have much choice because the screw has a shoulder and must go in last . So I cobbled that back together , just enough so it worked !
Ten minutes later the other assembly blew up ! This one has an allen screw and 3 washers ! Also cobbed together to make it work ! Same situation , there is a shoulder on the screw ! The other washers I did use are black !
So I figured if I found a parts blow up I’de be able what the order of washers is ! WRONG !
So here I am ! Any help !
