Hi guys, looking for some advice im looking at buying the Milwaukee M18FHIW2F12-0 M18 FUEL impact gun.
I already have 3 5ah batteries, but im looking at getting a bigger battery for the heavy use gun. My question is, can you put a 8ah battery on one of these guns and expect it to last, as iv been told they burn up quite quick with bigger battery’s.
Any info much appreciated!!
I haven’t seen them burn out with bigger batteries. I see them being used all the time. Mostly with 5Ah batteries.
Been told by who? Larger batteries will extend power / runtime, but the lifespan of the tool depends on things like the quality, design, and strength of the internal parts. As long as you use the proper voltage battery I don’t see how amperage that you use will decrease lifespan.
RT29 wrote:
On 4/21/2025 at 7:28 PM, RT29 said:Been told by who? Larger batteries will extend power / runtime, but the lifespan of the tool depends on things like the quality, design, and strength of the internal parts. As long as you use the proper voltage battery I don’t see how amperage that you use will decrease lifespan.
To be fair, that is my personal oppinion, but it seems to be general consensus that in no way shape or form should one of the big 12ah batteries be put onto say a M18 1/2 gun, in my garage atleast. As they are all compatible, shouldn’t that mean the tool should support the larger capacity batteries?
I’m in a bit of a mine field ATM as I have no precise answer lol
Who gave you that rubbish info?
The only issue with big batteries on an impact tool is that the hammer action cause the batteries to pretty much disintegrate and wear out the contact area between the battery and the tool.
Due to the weight of bigger batteries, I would only use a 5 or 6ah battery, just have a couple of them on hand for long jobs, they don’t take long to charge.
