black fulkr cock hub got loads of hq dick clips plus filter ya fkn gay cams by age viewers rating hard cocks naked dudes raw live sx non fkn stop
https://gaypornwebsite.com/videos/papi-joven/
https://gayporn.name/videos/45573/brunette-straight-guy-rush-masturbating/
I had the Dewalt DW735 which is the 15 Amp planner. I never had any issues with the motor and had it for a long time. Now I didn’t use it everyday, probably only used it about 100 times in those years. I really only ran either Oak, Purple heart wood, which both are hardwoods. I also ran a lot of pine through it also.
I found that I could not take a lot of at once. If I was running pine through it, I could take of 1/16″ at most. I believe the manual said I could take of an 1/8″ in the aggressive mode but the circuit breaker would always pop. If it was oak or other hard wood, the most I could take of was 1/32″ per pass. If I tried to take of 1/16″, it would pop the breaker most of the time.
Not sure which Dewalt you have but I would think there is a breaker on the machine instead of burning out the motor twice, weird.
I have the 734 and no issues with it burning out either. Not the highest quality of cut but nothing a little sanding can’t fix for my application. Planers do seem to take a lot of juice. Very high starting amps. My Ego Nexus wont even run mine. I need a proper wall outlet to run the planer.
Grizzly just came out with a new model that kinda sorta competes with the 735 DeWALT and the comparable Oliver.
Eucalyptus is really hard, it can kill an engine too fast. If I were you, I would look on the side of beefier industrial models or a cast iron roller planer.
