What hand or power tools resemble “Ninja-themed” weapons?
Cartoondude135Member since May 2021
I’m making something a little more interesting: a ninja-themed construction crew with weapons that resemble hand or power tools.
Let’s take for one: circular saw blades from hand held cut off saws and disk cutters; (with their different designed teeth) they resemble ninja/throwing stars if you shrink them down to size.
So… is there any other tools (both hand and powered) that resemble ninja weapons like that?
fm2176Member since Feb 2017
Interesting topic…  It might stretch the imagination, but some reciprocating saw blades resemble reverse tanto designs, so perhaps some blades like those in this set: 8 piece 2X Recip Blade Set with ToughCase® | DEWALT.
When it comes to aesthetics, it might be a bit easier to achieve that ninja theme.  If 2020 taught us anything, it’s that face masks can turn anyone into a ninja, so trade in the white N95 masks for some black ones and outfit the crew in form-fitting black garb with adequate padding (to protect against both bumps and bruises on the jobsite and hostile opponents), and you’ve got your ninja crew.  😄
