Drill Bit Gets Stuck. Why?
mgmartinoMember since May 2024
Hello,
I was drilling pilot holes in the wood step area of my door jamb and my 5/64th black oxide drill bit got stuck. I switch the button on my drill to reverse it and the drill bit didn’t come out. I kept my finger on the trigger and started to pull, and eventually the power drill pulled up but the drill bit was stuck in there.
Tried to get it out with a vice grip and channel locks, no luck. Eventually the drill bit snapped, luckily it snapped in a way where it was flush with the hole so it didn’t cause serious issue for on instillation my door threshold.
The 2nd hole the gave me issues ( I also point out in the video) Luckily on that one I was extra cautious so when I felt a little resistance I started to pull it out. But again the power drill was unscrewing it but the drill bit wasn’t spinning, I kind wiggled it around while the power drill still had it’s claws on the drill bit and yanked it out without breaking the bit. I show that bit still attached to the drill in the video also.
I don’t know if it is worth mentioning but this is an exterior door and it was about 31-35° F out
Good question and wish I could help give an exact reason but not sure.  The house does look old by the wood that is under the threshold.  My house was built in 1924 and I just remodeled most of the house.  I had an area below my threshold that had a piece of old metal below the wood.  I have no idea what the purpose was or why it was there.  When I drilled for my threshold, I couldn’t understand why the bit was going all the way through the wood.  After a while, I figured out that there was metal below, it wasn’t thick but enough to be a pain.  I am wondering if you have a piece of metal below and maybe it catching on the side of the metal causing issues.  I doubt it, but I can’t think of anything else why the other holes drill easy and the last two cause issues.
I just might! Because on another forum someone responded to me saying
“The OP’s drill’s chuck jaws apparently had high enough of torque applied onto the bit, that when the drill bit tip jammed into the concrete/nail/metal flashing(?)that is below the threshold, the drill bit broke.”
Maybe older homes is was common to lay a metal or reinforce material under the threshold. I have no idea why. But it might be what happened to me as well.
What Eric said makes sense and might be the case. What I would do normally is to mark the holes with a pen first and then drill the wood without having that metal piece on the wood, when you drill with a small size drill bit through two different materials (wood and metal) with a bit of move to left or right you can break the drill bit as it gets stuck to the metal piece, also when you drill try to drill a bit in first and then out and then in again, like in and out in a few steps, not all the way in till the end so you empty the hole. Big no to black oxide drill bits! Better to use high quality HSS or HSS Co drill bits always.
