First mitre saw. First mistake 6955-20 adjustment gone awry
podricMember since Nov 2024
I have a new to me Milwaukee 6955-20.  This thing is a beast at 75lbs.  It isn’t small either.
The miter bevel was stiff and Milwaukee told me there was no torque spec for it so I backed off the nut a little and loosened it up.
The miter bevel was also not dead center and so read the manual and went to do the adjustment.
I did not use the Milwaukee tool to hold the big red bevel brake arm release.  I used a screw driver.
The front 2 torx screws were backed off.  The first time they were backed off I could not move the adjustment screw much without resistance; maybe I should have forced it a bit?
I backed the 2 torx screws further off and the adjustment screw moved with greater range.  Still I was unable to do the minor adjustment on the bevel as the screw did nothing.
I tightened up the 2 torx screws on the front so I could try again later.
NOW: the bevel brake release does not stay in the detent search position and I can sense no positive action on the bevel detent.  When the lever does stay up it does not fall on a detent.
I am at a loss, I can see inside a little with the scope and can see from the back place but the mechanism is partially hidden from my view via  1″ squarish metal plate on a part.
The milwakee rep said maybe tightening the brake cable would help but did not know for sure.
How do I get this saw back on track?
thank you for reading
millsmark21Member since Dec 2024
Thank you for reading
The adjustment mechanism might be misaligned. Try carefully loosening the bevel brake release again and ensure the detent is properly aligned. If tightening the brake cable doesn’t work, you might need to disassemble the front plate to realign the internal components..
