What’s the best blade to use on the milwaukee m18 multitool as I’ve tried different ones and it seems to burn rather than cut clean. The ones I use most is the smart blades . Not sure if it’s the blades, tool or me . Thanks
I am a huge fan of Bosch or Diablo blades. They should last as long as your not hitting metal or pushing hard, let the tool do the work. If you think you will be hitting nails or screws, use a Carbide blade. They are a lot more money, but will last when you go through metal.
