I have a Dewalt 6inch 60 volt grinder that after extended use one day quit working. I assumed I burned it up or at least smoked the trigger but I found that if I remove the battery then reinstall it the grinder will run as long as I hold the trigger. If I release the trigger it won’t restart unless I remove and replace the battery then it will restart and remain running as long as I hold the trigger. Any ideas as to what the issue might be?
Tia
Dan
