Ryobi HP 18V Secatuers
Andrew Down UnderMember since May 2024
I removed the blade to clean it and when I went to put it back together, the malfunction light came on.  Now it seems as though the blade holder no longer aligns correctly with the gears in the motor.  When I turn it on in the open position it does nothing.  If I troubleshoot it by manually putting the blade in the closed position and turn it on, then it opens and quits.  HELP??
NOTE: Later, I read in one manual that I was suppose to change the blade while it was in the closed position, however a different manual I looked at had it in the open position so I’m not sure if that matters or not.  I originally disassembled it in the open position.
