Performax 16/32 Drum Sander Help Needed
CivrelMember since Mar 2024
I have an old Performax 16-32 drum sander that was in a fire.  It didn’t burn, but had smoke and water damage and some heat damage.  It seems to work fine, but I get a weak shock when it runs. The open circuit is 120 volts and about 3 amps on a meter.    I have taken it apart and tested as follows:
Unplugged the drum motor and plugged it into power and no voltage measured across the machine, so I don’t believe that’s the problem.
I checked the receptacle where the drum motor plugs in and is fine, no melting and no loose wires.
I did not see any melted or bare wires inside the control housing and power cord.
The conveyor motor is a 90-volt DC motor, it runs fine and adjusts speed when the potentiometer dial is turned.  Not sure how to test the DC motor or the potentiometer dial.  There is a Jet replacement, just pricy ($$$).  Any suggestions how to proceed to narrow down what’s causinf the shock?
