12Amp flexvolt battery
Ron davidMember since Jan 2024
Hello everyone,
The battery is quite new and started to have problems. After checking the voltages, I understand that everything is fine, the battery outputs 60v and 20v, but the battery itself discharges faster than usual, After a full discharge, I charge it with a dcb118 charger that produces 8amp per hour, and found that the battery finished charging after 45 minutes, which means it was charged at 6 amps with three full bars.
Does anyone know what the problem could be, and how is it possible that the battery has half its capacity after a full charge?
TugMember since May 2017
I’ve just had a 12 Amp pack swapped by Dewalt because it was down on capacity. I’d owned it for eleven months before I noticed. Have you contacted them?
