Is there a brand of sandpaper that’s known for not clogging up? Ideally available in sheets. I’m about to be sanding a resin project up to 600 grit and I can see going through some sandpaper if it clogs up easily on this resin. I’ll be chilling the piece before sanding to try to combat any heat buildup. Thanks.
Good question. I think Diablo has some that they claim doesn’t clog up with their sandnets sheets but I haven’t used them on that application.
A vacuum sander, like my Festool RO150FEQ, w/ proper usage of the tool and proper paper selections, is the best option to avoid the paper being clogged.
