I have the old model. I wonder what is different about this model.
Jronman wrote:
10 hours ago, Jronman said:I have the old model. I wonder what is different about this model.
The DCGG581 DeWALT 18V XR 2-Speed Grease Gun is perfect to use for a variety of lube maintenance applications ranging from Automotive, Factory, Heavy Equipment & Agricultural applications. These grease guns provide up to 10,000PSI Max Pressure and have a 1.2m long hose which provide greater accessibility around machinery.
- 10,000PSI Push Force – Max 10,000 PSI pressure to power through clogged grease fittings in speed one
- 2-Speed – Low 85g/min High 255g/min for increased versatility of application
- Ergonomic Grip Areas – Over-moulded & sculptured to fit the hand for optimum comfort & control
- Variable Speed Trigger – Add the precise amount of grease less waste
- Extra Long Grease Hose – 1.2m long reinforced hose for greater accessibility around machinery
- Bleeder Valve – Releases air in front of the grease tube makes it easy to prime pump when changing cartridges
- Bright Led – Illuminate work area for easier alignment of nozzle in hard to reach areas
- Cartridge Holder (ANZ 450G) – Screw top lid with that is easy to load with grease for greater user convenience
