Hi,
I need to cut quarters of plywood sheets (24″x49″) into small pieces at 90 degree angles, accurately.
Ideally, it was not necessary to make any adjustments to the cuts and that the cut pieces came out perfect, with extreme precision, perfect right angles and with fine cuts.
I already have the TS 55 FEBQ-Plus-FS.
Is the MFT/3 system capable of doing this?
Thanks.
Before track saws and all the newfangled doohickeys etc, carpenters and woodworkers made their own straight edges. You circular saw should have a plate that can angle to cut at whatever angle you need. And for thin wood get a trim blade like 60-80 tooth. $20 at home depot. And put blue painters tape on both sides where the cut line is.
