Is the a vendor that sells Ryobu 48v lawnmower battery recharger. QL-91435A-4801500H.
I tried Ryobi and they do not have the part nor does the aftermarket seller they pushed me to.
Mower works. Shame to toss it bc I cannot get a charge.
Thanks
Dave
Did you find a charger?
It’s a Delta Q SC-48 charger. It’s supposedly custom set up to Ryobi’s specs., but they are also used for golf carts. There were different Ryobi p/ns based on the mower’s manufacturer number listed on the label under the seat. If you find a source, make sure the p/n matches the one on your original charger.
Worst case, you could pull the battery tray per the manual instructions, disconnect the wiring, and charge each battery with a regular 12 volt battery charger, and then put it all back together. I can pull the battery tray in about 30 minutes.
What’s wrong with the charger? Is it showing any led indicators?
