Bosch Electric Lawn Mower won’t stop mowing
KitNorskMember since May 2022
So, as the title says, when I turn on the lawn mower, and then let go of it entirely, it stays on. I can turn it off by flipping the switch, but otherwise it stays on.
For obvious reasons, I have my issue with this, and I can’t seem to figure out the problem, nor do I find this topic addressed in any other forums.
Please answer quickly, the grass grows fast here, and I’m already a few days behind. 😅
Update: It seems I managed to fix it afterall. I cleaned out the machine, I guess some leaves or dust got in by the electronics
TortugaMember since Dec 2021
KitNorsk wrote:
No reason for it to go to waste as long as it’s running, do you need my address? 🤣
supplyvantoolsMember since Mar 2022
Is your problem properly fixed now? Are you facing some other issue?
millsmark21Member since Dec 2024
my friend also had a similar issue and he call a local electrical repair pro to take a look and fix the issue,
but the electricien from electricienchateauguay.ca just clean it and it starts working, i am also going to try this
hack, and will update if it works.
yeah, cleaning tools is often the best first step when something’s not functioning right, as it can prevent sensors or connections from working properly.
