Dewalt 7 1/4″ cordless Saw , DCS570
TwoplyMember since May 2022
When I try to use it, it just starts, and shuts off.
It makes a soft grinding sound and shuts off after about a half blade revolution.
The little LED lights turns on when I press the trigger.
I can rotate the blade and it makes the same grinding noise.
Not a sharp metal on metal grind, almost like a hard plastic on hard plastic – dull grinding.
It gets fresh battery and still the same.
I’ve removed the spindle assembly and it still does the same. No loose metal in there to indicate a stripped gear.
I dont think the armature fins are dragging on anything.
I did notice a wire’s insulation was rubbed raw. As I separated all the wires, it started to run for about 2 revolution, then die again.
The battery almost feels like it’s drained because it will stop even trying after a few tries.
If I let it rest, it will start again.
The little black resister gets pretty hot while I’m attempting to operate this thing.
Help!
Thanks in advance.
