M18 Fuel 1/4″ Hex Impact Driver (2850-20) Battery Memory issue
MerZed JerZedMember since Apr 2022
I have had a very interesting issue with 2 Fuel tools recently. First my 2850-20 Impact Driver decided to stop working. Plug in a battery, led turns on but trigger does nothing. Wait 5 minutes, the led will ignite with trigger depressed but motor won’t spin.
Next day, M18 Fuel 7-1/4 Circular Saw (2631-20) decided to do the same thing only the led ignites at every trigger depression.
Next day, saw seems to have fixed itself (for now) but a discovery was made with the impact.
Step 1-insert battery from charger into 2850-20 impact, doesn’t spin motor.
Step 2-insert same battery into any other tool and run it (important step)
Step 3-insert battery back into 2850-20 impact and it will work fine (for a few minutes) every time. After a certain amount of time of inactivity, it won’t work again and you will have to repeat Steps 2 & 3 to get it to work again.
Almost as if there is a computer issue related to battery memory in my impact?
Any help is appreciated, thank you,
Confused Customer
fyrfytr998Member since Mar 2022
That seems like a lot of work. I’d just go buy another Impact.
Thank you for your input.
