Fabrication cost of engraving stainless is likely the reason for only plastic or aluminum.
wingless wrote:
58 minutes ago, wingless said:Fabrication cost of engraving stainless is likely the reason for only plastic or aluminum.
I have a Triangle of this and also this one in 25cm x 50cm and it is made of stainless steel and price was around 15 USD I think, quite well made, I think the problem is not the cost of engraving the stainless steel, the problem is the thicker part of the rafter square and we can not make it from sheet stainless steel.
wingless wrote:
14 minutes ago, wingless said:
I think this has been made of two pieces, no?!
