Dewalt 54V Flex Volt Chain Saw
Darren WoodMember since Mar 2022
The chain saw through a wobbly recently and I had to replace the chain drive sprocket, washer and bolt ( the bolt head snapped off ! ). Prior to this happening the chainsaw would use a reasonable amount of oil and I needed to top it up every couple of battery changes. Now since i replaced the above parts it seems to be using no oil at all.
Are there any area’s around that chain sprocket and the spring that surrounds it underneath and the blade tensioning bar that I could have touched by mistake that would affect the oil to the chain ? Where does the oil exit onto the chain ?
Hope you can help
Thanks
