I’m absolutely tired of renting here. I need a drill for driving ground rods and soil is moderately hard one
I wanted to know how big/heavy drill I need for ground rods. 10-13 amps, and around 12-15 lbs. Will that be enough? i know demo hammers are usually a bit higher than that
Have done quite a bit of research on the internet. it seems most prefer demolition hammer.
Also few suggesting SDS Max/Plus Rotary Hammer Drills are quite effective.
like always, i don’t want to waste my hard earned money.
What you guys actually do? Will greatly appreciate any advice, thanks
Welcome to the forum.
When I drive my ground rods I use my Bosch RH540M SDS-Max Rotary Hammer w/ a TEMCo TH0376 5/8″ bore SDS-Max ground rod driver adapter bit. It is a short bit w/ a cylindrical cavity at the end.
The ground rods go into the Earth like a hot knife through butter. There is sometimes a rock slowing progress, but I just wait for a second, then it continues to the desired depth.
Unlike using a sledge hammer, the ground rod end looks new.
FWIW the grounding on the house shown in the image was horrible before it was fixed by me. There was a 3′ ground rod, not even buried, w/ a solid 10AWG bare wire connection to the main panel, nothing to the copper plumbing. Now everything is done to current code.
