My guess is the pin is still engaged and holding the blade in place since it will move side to side. I believe that has a chuck release on the side where you lift up. If so, take a look to see if it is even engaging the chuck. If not, use a screwdriver and you should be able to push up on the chuck and release the blade. If not let me know.
@Eric – TIA I am having the same issue. The pin will not disengage. dw303. Tried lubricant, pliers, screwdriver. Bout ready to toss it
I had this happen on a DeWalt I used to have. Try holding the release lever and run the saw, and / or Try (with screw still removed) run saw and tap blade tip on the ground a few times while it is running. Hopefully one of these work.
