Flexvolt with 20v blower?
renochsMember since Jun 2021
I have a 20v Dewalt blower (DCBL720P1) that works great.  I just bought a trimmer that came with a 9Ah Flexvolt battery.  I assumed I would be able to use this in my blower as well.  However the FV battery does not fit inside the battery housing on the blower.  There are two small (1-2mm) rails on the bottom of the battery guard / tool rest that get in the way (see picture).  My question – is there a reason for this, or was it just a design oversight?  Could I trim down those rails a bit to allow the battery to fit, or am I asking for trouble if I do that?  The only potential issue I can think of is that the battery would extend beyond the “foot” a couple of millimeters so when you set down the tool it would rest on the battery.  I have not been able to find a compatibility chart that addresses this.
BiggieMember since Oct 2016
I had your exact same situation.  What I found is the 9ah will actually fit in the blower although it’s tight and takes a little flexing but it does go.  I think it’s just a design oversight and I’ve never had any issues running the blower with the 9ah.  Then again I’m just a homeowner that uses the blower to clean up my driveway, sidewalk and patio so I’m not draining a battery in a single use.
TradeCraftMember since Aug 2016
DCBL720 is an old design that predates the Flexvolt tool line. Some of the new FV batteries are much larger as you have found. Dewalt now also sells a FV blower.
Thanks, both.  I think I will just shave off that ridge with a Dremel and use it.
