Trick – How to make your own Sanding Belts
DIYfixmanMember since Aug 2019
In the next video I will show you how to make Sanding Belts yourself, it is very simple, easy and strong you can also make it in any size you need and with the help of easy to obtain raw materials you will find them in every store.
  1. Take the desired size of the belt and add another 2 cm along the general length and then cut.
  2. Mark the 2 cm and start scraping the glass layer out of the paper until you reach the silk felt.
  3. Clean dust and grease well and glue both ends of the strip with high-quality fast glue.
  4. Wait long enough for the glue to dry completely and it is possible to start using the belt.
It is important! At the stage where you scrape the glass layer out of the paper it is very important to remove the entire glass layer until you reach the silk felt, otherwise the adhesion will not be strong enough.
