Great question. When I get back in town I will look at mine. I never knew I had to grease it. I always thought it was a sealed grease compartment. Thanks for letting me know. When I look at mine, I will see what I can find.
Can somebody tell me what kind of grease do I need to buy for ego edger
Wild guess but fairly confident this is the answer. Make sure trimmer head is down, that’s the position you’d normally have it while in use, so the seal screw is facing to the right. the height of the seal screw is your 3/4 mark. You fill the gearbox up to that point with a syringe while turning the head to spread the grease. Hope this helps!
Sam
