Ryobi R7SD-L13G 7.2V cordless Drill – need a replacement charger
YetiMember since Jan 2021
Hi All,
I lost the charger for my Ryobi R7SD-L13G cordless drill and I am trying to identify the spec of the power supply.
The battery is 7.2V, so the power supply definitely has a higher voltage rating.
Here is what I know.
PSU Voltage must be greater than 7.2V
The DC-in port on the drill is 4mm wide and the DC-in port pin is 1.7mm  – so the tip on the power supply would be a 4/1.7mm concentric hollow barrel type tip.
Missing Info:
PSU output Voltage
Amperage
Polarity – not sure if it is center negative polarity or center positive polarity.
If somebody could send me a picture of the spec label on their charger (for the Ryobi R7SD-L13G), I would really grateful. The drill is in perfect condition and I just want to keep using it for drilling pilot holes.
Even a link to the manual would be very helpful.
Thanks,
Yeti.
Thesicillian2002Member since Jan 2021
Hi Yeti,
Ryobi R7SD-L13G chargers part number is: 5131039358
You can order a replacement from www. cjsinclairltd.co.uk
Cheers
MicheleMember since Mar 2022
Yeti wrote:
On 1/15/2021 at 11:35 AM, Yeti said:
Hi All,
Missing Info:
PSU output Voltage
Amperage
Thanks,
Yeti.
Hi Yeti. I have the same problem as you, did you manage to get the data you were looking for? If you got them could you tell me? I would be very grateful.
Greetings
Michele
