Discontinued battery charger
A. CollinMember since Jan 2021
Black & Decker discontinued the plug in wall charger I need for their 18 V cordless drill and no oem replacement is available. Can I  use another manufacturers plug in wall charger.
fm2176Member since Feb 2017
Most likely, no.  B&D is part of Stanley Black & Decker (SBD), however, so depending on the system you might find an SBD brand’s charger that works with minor modifications.  For example, the Porter Cable 12v Max and B&D 12v batteries were compatible if a tab was removed.
I’d recommend trying to find a used charger.
Thanks , do you recommend any specific site for used chargers? I checked e bay and no luck. Funny thing is a friend bought me this drill from the pawn shop with no charger but the drill had enough charge to ensure it worked.
